emonTx Arduino Shield v2.4 usable to send data to a pi or homeassisant?
but use 9600
[edit]
If it is not getting data, switch RX/TX as a first option.
w00t
Ok have data in miniterm… now what lol
looks like it should be right. - delete the other one.
Modify the pub/sub as above
restart emonhub
sudo systemctl restart emonhub.service and post the initial log.
Oh and fix SSH :grinning:
lol, I shall fix the ssh.
When you say post the initial log, I assume you are referring to the emonhub.log? I can get that from the gui?
2021-03-15 10:54:24,757 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:24,759 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 8 times...)
2021-03-15 10:54:24,760 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:24,762 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:24,764 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:30,521 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
  File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 32, in wrapper
    return func(*args)
  File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 99, in run
    rxc = self.read()
  File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubSerialInterfacer.py", line 90, in read
    c.nodeid = int(f[0])
ValueError: invalid literal for int() with base 10: 'P1:4.09,P2:0.00,P3:-0.00,P4:1.36,Vrms:23936.72'
2021-03-15 10:54:30,637 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:30,639 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 9 times...)
2021-03-15 10:54:30,640 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:30,643 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:30,644 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:36,406 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:1.94,P2:0.00,P3:-0.00,P4:4.47,Vrms:23964.12'
2021-03-15 10:54:36,455 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:36,456 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 10 times...)
2021-03-15 10:54:36,457 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:36,461 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:36,468 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:42,281 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:5.18,P2:-0.19,P3:0.00,P4:-3.38,Vrms:23977.97'
2021-03-15 10:54:42,479 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:42,480 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 11 times...)
2021-03-15 10:54:42,482 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:42,485 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:42,487 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:48,045 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:4.14,P2:-0.00,P3:0.00,P4:4.73,Vrms:23971.27'
2021-03-15 10:54:48,096 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:48,097 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 12 times...)
2021-03-15 10:54:48,099 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:48,101 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:48,103 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:53,964 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:3.43,P2:-0.00,P3:0.00,P4:2.52,Vrms:23938.50'
2021-03-15 10:54:53,980 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:53,981 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 13 times...)
2021-03-15 10:54:53,983 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:53,985 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:53,986 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:54,161 DEBUG    MainThread Signal 15 received.
2021-03-15 10:54:54,190 INFO     MainThread Exiting hub...
2021-03-15 10:54:54,393 INFO     MainThread Exit completed
2021-03-15 10:54:57,567 INFO     MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-03-15 10:54:57,569 INFO     MainThread Opening hub...
2021-03-15 10:54:57,570 INFO     MainThread Logging level set to DEBUG
2021-03-15 10:54:57,572 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:57,576 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:57,577 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:54:57,580 INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-03-15 10:54:57,585 DEBUG    MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-03-15 10:54:57,586 DEBUG    MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-03-15 10:54:57,587 INFO     MainThread Setting MQTT node_format_enable: 1
2021-03-15 10:54:57,588 INFO     MainThread Setting MQTT nodevar_format_enable: 1
2021-03-15 10:54:57,589 INFO     MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-03-15 10:54:57,590 INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-03-15 10:54:57,592 DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-03-15 10:54:57,593 DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-03-15 10:54:57,594 WARNING  MainThread Setting emoncmsorg apikey: obscured
2021-03-15 10:54:57,595 INFO     MainThread Setting emoncmsorg url: https://emoncms.org
2021-03-15 10:54:57,596 INFO     MainThread Setting emoncmsorg senddata: 1
2021-03-15 10:54:57,596 INFO     MainThread Setting emoncmsorg sendstatus: 1
2021-03-15 10:54:59,730 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:0.18,P2:-0.00,P3:0.00,P4:1.13,Vrms:23967.49'
2021-03-15 10:54:59,922 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:54:59,924 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 0 times...)
2021-03-15 10:54:59,925 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:54:59,928 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:54:59,929 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:55:05,587 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:-0.03,P2:-0.00,P3:0.00,P4:3.20,Vrms:24038.24'
2021-03-15 10:55:05,769 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:55:05,770 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 1 times...)
2021-03-15 10:55:05,772 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:55:05,775 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:55:05,776 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:55:11,439 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:4.23,P2:-0.00,P3:0.00,P4:1.43,Vrms:24010.20'
2021-03-15 10:55:11,642 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:55:11,643 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 2 times...)
2021-03-15 10:55:11,645 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:55:11,648 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:55:11,649 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 10:55:17,305 WARNING  SerialDirect Exception caught in SerialDirect thread. Traceback (most recent call last):
    return func(*args)
    rxc = self.read()
ValueError: invalid literal for int() with base 10: 'P1:4.95,P2:0.00,P3:-0.00,P4:1.48,Vrms:24007.38'
2021-03-15 10:55:17,515 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 10:55:17,516 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 3 times...)
2021-03-15 10:55:17,517 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 10:55:17,519 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 10:55:17,520 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
added nodeID 6 to the payload.
now getting this error:
21-03-15 11:17:00,336 WARNING  MainThread SerialDirect thread is dead.
2021-03-15 11:17:00,337 WARNING  MainThread Attempting to restart thread SerialDirect (thread has been restarted 88 times...)
2021-03-15 11:17:00,338 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 11:17:00,341 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 11:17:00,342 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 11:22:43,364 INFO     MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-03-15 11:22:43,366 INFO     MainThread Opening hub...
2021-03-15 11:22:43,376 INFO     MainThread Logging level set to DEBUG
2021-03-15 11:22:43,377 INFO     MainThread Creating EmonHubSerialInterfacer 'SerialDirect'
2021-03-15 11:22:43,382 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2021-03-15 11:22:43,383 DEBUG    MainThread Setting SerialDirect pubchannels: ['ToEmonCMS']
2021-03-15 11:22:43,387 INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-03-15 11:22:43,406 DEBUG    MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-03-15 11:22:43,409 DEBUG    MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-03-15 11:22:43,411 INFO     MainThread Setting MQTT node_format_enable: 1
2021-03-15 11:22:43,413 INFO     MainThread Setting MQTT nodevar_format_enable: 1
2021-03-15 11:22:43,414 INFO     MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-03-15 11:22:43,434 INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-03-15 11:22:43,436 DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-03-15 11:22:43,437 DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-03-15 11:22:43,438 WARNING  MainThread Setting emoncmsorg apikey: obscured
2021-03-15 11:22:43,439 INFO     MainThread Setting emoncmsorg url: https://emoncms.org
2021-03-15 11:22:43,441 INFO     MainThread Setting emoncmsorg senddata: 1
2021-03-15 11:22:43,442 INFO     MainThread Setting emoncmsorg sendstatus: 1
2021-03-15 11:30:22,920 DEBUG    SerialDirect 1 NEW FRAME : 6 P1:0.50,P2:-6.32,P3:13.52,P4:0.43,Vrms:23977.61
2021-03-15 11:30:22,921 WARNING  SerialDirect 1 Discarded RX frame 'non-numerical content' : ['P1:0.50,P2:-6.32,P3:13.52,P4:0.43,Vrms:23977.61']
2021-03-15 11:30:28,777 DEBUG    SerialDirect 2 NEW FRAME : 6 P1:1.62,P2:-1.44,P3:4.21,P4:0.16,Vrms:23952.69
2021-03-15 11:30:28,778 WARNING  SerialDirect 2 Discarded RX frame 'non-numerical content' : ['P1:1.62,P2:-1.44,P3:4.21,P4:0.16,Vrms:23952.69']
2021-03-15 11:30:34,624 DEBUG    SerialDirect 3 NEW FRAME : 6 P1:7.01,P2:-0.49,P3:1.46,P4:2.62,Vrms:23857.85
2021-03-15 11:30:34,625 WARNING  SerialDirect 3 Discarded RX frame 'non-numerical content' : ['P1:7.01,P2:-0.49,P3:1.46,P4:2.62,Vrms:23857.85']
2021-03-15 11:30:40,486 DEBUG    SerialDirect 4 NEW FRAME : 6 P1:16.03,P2:-0.40,P3:0.48,P4:5.82,Vrms:23988.38
2021-03-15 11:30:40,487 WARNING  SerialDirect 4 Discarded RX frame 'non-numerical content' : ['P1:16.03,P2:-0.40,P3:0.48,P4:5.82,Vrms:23988.38']
2021-03-15 11:30:46,336 DEBUG    SerialDirect 5 NEW FRAME : 6 P1:5.84,P2:-0.15,P3:0.14,P4:-0.46,Vrms:23966.14
2021-03-15 11:30:46,337 WARNING  SerialDirect 5 Discarded RX frame 'non-numerical content' : ['P1:5.84,P2:-0.15,P3:0.14,P4:-0.46,Vrms:23966.14']
2021-03-15 11:30:52,088 DEBUG    SerialDirect 6 NEW FRAME : 6 P1:5.13,P2:-0.18,P3:0.13,P4:-1.86,Vrms:23872.28
2021-03-15 11:30:52,090 WARNING  SerialDirect 6 Discarded RX frame 'non-numerical content' : ['P1:5.13,P2:-0.18,P3:0.13,P4:-1.86,Vrms:23872.28']
2021-03-15 11:30:57,943 DEBUG    SerialDirect 7 NEW FRAME : 6 P1:8.01,P2:-0.03,P3:0.02,P4:0.95,Vrms:23838.20
2021-03-15 11:30:57,944 WARNING  SerialDirect 7 Discarded RX frame 'non-numerical content' : ['P1:8.01,P2:-0.03,P3:0.02,P4:0.95,Vrms:23838.20']
restart with first lines like you asked:
pi@emonpi:~ $ sudo service emonhub restart && tail -f /var/log/emonhub/emonhub.l                                                          og
2021-03-15 11:43:30,485 WARNING  SerialDirect 73 Discarded RX frame 'non-numeric                                                          al content' : ['P1:4.82', ',P2:0.00', ',P3:-0.00', ',P4:-0.59', ',Vrms:23974.43'                                                          ]
2021-03-15 11:43:36,270 DEBUG    SerialDirect 74 NEW FRAME : 6 P1:3.26 ,P2:0.00                                                           ,P3:-0.00 ,P4:-2.37 ,Vrms:23818.84
2021-03-15 11:43:36,271 WARNING  SerialDirect 74 Discarded RX frame 'non-numeric                                                          al content' : ['P1:3.26', ',P2:0.00', ',P3:-0.00', ',P4:-2.37', ',Vrms:23818.84'                                                          ]
2021-03-15 11:43:42,132 DEBUG    SerialDirect 75 NEW FRAME : 6 P1:6.30 ,P2:0.00                                                           ,P3:-0.00 ,P4:7.19 ,Vrms:23959.72
2021-03-15 11:43:42,133 WARNING  SerialDirect 75 Discarded RX frame 'non-numeric                                                          al content' : ['P1:6.30', ',P2:0.00', ',P3:-0.00', ',P4:7.19', ',Vrms:23959.72']
2021-03-15 11:43:47,980 DEBUG    SerialDirect 76 NEW FRAME : 6 P1:5.32 ,P2:0.00                                                           ,P3:-0.00 ,P4:7.09 ,Vrms:23961.17
2021-03-15 11:43:47,981 WARNING  SerialDirect 76 Discarded RX frame 'non-numeric                                                          al content' : ['P1:5.32', ',P2:0.00', ',P3:-0.00', ',P4:7.09', ',Vrms:23961.17']
2021-03-15 11:43:49,565 DEBUG    MainThread Signal 15 received.
2021-03-15 11:43:49,598 INFO     MainThread Exiting hub...
2021-03-15 11:43:49,710 INFO     MainThread Exit completed
2021-03-15 11:43:52,679 INFO     MainThread EmonHub emonHub (emon-pi variant) v2                                                          .1.5
2021-03-15 11:43:52,681 INFO     MainThread Opening hub...
2021-03-15 11:43:52,682 INFO     MainThread Logging level set to DEBUG
2021-03-15 11:43:52,683 INFO     MainThread Creating EmonHubSerialInterfacer 'Se                                                          rialDirect'
2021-03-15 11:43:52,687 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @                                                           9600 bits/s
2021-03-15 11:43:52,689 DEBUG    MainThread Setting SerialDirect pubchannels: ['                                                          ToEmonCMS']
2021-03-15 11:43:52,691 INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT                                                          '
2021-03-15 11:43:52,695 DEBUG    MainThread Setting MQTT pubchannels: ['ToRFM12'                                                          ]
2021-03-15 11:43:52,696 DEBUG    MainThread Setting MQTT subchannels: ['ToEmonCM                                                          S']
2021-03-15 11:43:52,697 INFO     MainThread Setting MQTT node_format_enable: 1
2021-03-15 11:43:52,698 INFO     MainThread Setting MQTT nodevar_format_enable:                                                           1
2021-03-15 11:43:52,699 INFO     MainThread Setting MQTT nodevar_format_basetopi                                                          c: emon/
2021-03-15 11:43:52,702 INFO     MainThread Creating EmonHubEmoncmsHTTPInterface                                                          r 'emoncmsorg'
2021-03-15 11:43:52,704 DEBUG    MainThread Setting emoncmsorg pubchannels: ['To                                                          RFM12']
2021-03-15 11:43:52,705 DEBUG    MainThread Setting emoncmsorg subchannels: ['To                                                          EmonCMS']
2021-03-15 11:43:52,706 WARNING  MainThread Setting emoncmsorg apikey: obscured
2021-03-15 11:43:52,707 INFO     MainThread Setting emoncmsorg url: https://emon                                                          cms.org
2021-03-15 11:43:52,708 INFO     MainThread Setting emoncmsorg senddata: 1
2021-03-15 11:43:52,709 INFO     MainThread Setting emoncmsorg sendstatus: 1
2021-03-15 11:43:53,802 DEBUG    SerialDirect 1 NEW FRAME : 6 P1:7.21 ,P2:0.00 ,P3:0.00 ,P4:-5.13 ,Vrms:23970.64
2021-03-15 11:43:53,803 WARNING  SerialDirect 1 Discarded RX frame 'non-numerical content' : ['P1:7.21', ',P2:0.00', ',P3:0.00', ',P4:-5.13', ',Vrms:23970.64']
2021-03-15 11:43:59,659 DEBUG    SerialDirect 2 NEW FRAME : 6 P1:1.42 ,P2:-0.00 ,P3:-0.00 ,P4:1.51 ,Vrms:23870.94
2021-03-15 11:43:59,660 WARNING  SerialDirect 2 Discarded RX frame 'non-numerical content' : ['P1:1.42', ',P2:-0.00', ',P3:-0.00', ',P4:1.51', ',Vrms:23870.94']
Got it working!!!
Had to change the loop in the sketch, wants only numerical values, so no key value pairs:
  EmonTx CT123 Voltage Serial Only example
  Part of the openenergymonitor.org project
  Licence: GNU GPL V3
  Author: Trystan Lea
#include "EmonLib.h"
// Create  instances for each CT channel
EnergyMonitor ct1,ct2,ct3, ct4;
unsigned long lastpost = 0;
const int nodeID = 6;
// On-board emonTx LED
const int LEDpin = 9;
void setup()
  // Setup indicator LED
  pinMode(LEDpin, OUTPUT);
  digitalWrite(LEDpin, HIGH);
  Serial.begin(9600);
  // while (!Serial) {}
  // wait for serial port to connect. Needed for Leonardo only
  Serial.println("emonTX Shield CT123 Voltage Serial Only example");
  Serial.println("OpenEnergyMonitor.org");
  Serial.print("Node: ");
  Serial.print(nodeID);
  // Calibration factor = CT ratio / burden resistance = (100A / 0.05A) / 33 Ohms = 60.606
  ct1.current(1, 60.606);
  ct2.current(2, 60.606);
  ct3.current(3, 60.606);
  ct4.current(4, 60.606);
  // (ADC input, calibration, phase_shift)
  ct1.voltage(0, 300.6, 1.7);
  ct2.voltage(0, 300.6, 1.7);
  ct3.voltage(0, 300.6, 1.7);
  ct4.voltage(0, 300.6, 1.7);
 lastpost = 0;
  delay(2000);
  digitalWrite(LEDpin,LOW);
void loop()
  // Calculate all. No.of crossings, time-out
  ct1.calcVI(20,2000);
  ct2.calcVI(20,2000);
  ct3.calcVI(20,2000);
  ct4.calcVI(20,2000);
Serial.print(nodeID);     Serial.print(' ');
Serial.print(ct1.realPower); Serial.print(' ');
Serial.print(ct2.realPower); Serial.print(' ');
Serial.print(ct3.realPower); Serial.print(' ');
Serial.print(ct4.realPower); Serial.print(' ');
Serial.print(ct1.Vrms*100.0); Serial.println();
  delay(5000);
Got the info from this link:
That’s because you have the wrong interfacer for that format. You are now using the Serial interfacer that requires space-separated values; the EmonHubTx3e Interfacer requires key:value pairs.
The latter carries the name of the variable with it, the former means the data arrives and you need to interpret what it is.
Ah, my bad, I said to remove the wrong one :frowning:
Thanks for all the help guys.
Really appreciate it, got it all up and running.
Hopefully, this thread will help someone else at some point.
Sorry, lol. Installed it all, was running nicely, but then after a power cut, my inputs have gone to minuses. Any idea at all why that would suddenly happen?
I thought it could only do that by putting the CT’s on the wrong way around. But I definitely had positive numbers when I switched it on to test it, and haven’t taken the CT’s off since then.
My initial thought is the calibration somewhere has got corrupted. I would start at the emonTx Shield and check that the outputs from that are sensible. If that looks OK, check the numbers in emonHub.conf
