They would show up randomly and i would just delete them, cannot remember if they showed before it crashed, i will keep a better log over the next few days.
Iāve seen this before. No explanation they just stopped eventually ![]()
My point is that an exception in the client loop should always be handled (whether it logs it or not) and not propagate upwards (as the log appears to show) or is that not how it works in PHP?
try {
$mqtt_client->loop();
} catch (Exception $e) {
if ($connected) $log->error($e);
For the item I linked to above, I think that perhaps it should be \Exception in the catch statement.
Iāll second that, mine shows these ārandomā inputs as well from time to time.
Up till now I was blaming the occurance on a bad packet.
While weāre on that topic. One issue I did notice with Paulās inputs as well as mine is that some of the input data will get truncated at random times so a reading of 110.1 may get truncated to 110.100000001. I have verified this data does not appear on the output stream of the emontx3 but does appear on the emonhub.
Can you provide more info or the emonhub.logs if it reoccurs?
This sounds like a simple float precision error but Iām not sure I understand correctly, ātruncateā is to shorten without rounding, 110.100000001 could get truncated to 110.1 but not the other way round. often if a value is cast to a float eg float(110.01) it might result in a value like 110.100000001.
@pb66
My bad, wrong choice of words there.
A current clip of emonhub shows the following:
2018-03-12 00:40:36,212 DEBUG MQTT Publishing: emon/emonpi/vrms 237.46
2018-03-12 00:40:36,214 DEBUG MQTT Publishing: emon/emonpi/t1 25.3
2018-03-12 00:40:36,215 DEBUG MQTT Publishing: emon/emonpi/t2 0
2018-03-12 00:40:36,217 DEBUG MQTT Publishing: emon/emonpi/t3 0
2018-03-12 00:40:36,218 DEBUG MQTT Publishing: emon/emonpi/t4 0
2018-03-12 00:40:36,219 DEBUG MQTT Publishing: emon/emonpi/t5 0
2018-03-12 00:40:36,221 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-12 00:40:36,222 DEBUG MQTT Publishing: emon/emonpi/pulsecount 87686
2018-03-12 00:40:36,224 INFO MQTT Publishing: emonhub/rx/5/values 8,9,17,237.46,25.3,0,0,0,0,0,87686
2018-03-12 00:40:36,315 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 32 0 0 0 0 52 96 0 32 32 0 3 160 0 32 0 0 32 224 (-104)
2018-03-12 00:40:37,024 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 2 0 8 0 96 175 36 0 42 108 0 137 224 42 68 20 192 44 78 128 (-99)
2018-03-12 00:40:41,044 DEBUG RFM2Pi 6559 NEW FRAME : OK 5 4 0 9 0 13 0 187 92 254 0 0 0 0 0 0 0 0 0 0 0 134 86 1 0 (-0)
2018-03-12 00:40:41,047 DEBUG RFM2Pi 6559 Timestamp : 1520815241.04
2018-03-12 00:40:41,048 DEBUG RFM2Pi 6559 From Node : 5
2018-03-12 00:40:41,049 DEBUG RFM2Pi 6559 Values : [4, 9, 13, 237.39000000000001, 25.400000000000002, 0, 0, 0, 0, 0, 87686]
2018-03-12 00:40:41,050 DEBUG RFM2Pi 6559 Sent to channel(start)' : ToEmonCMS
2018-03-12 00:40:41,051 DEBUG RFM2Pi 6559 Sent to channel(end)' : ToEmonCMS
2018-03-12 00:40:41,166 DEBUG MQTT Publishing: emon/emonpi/power1 4
2018-03-12 00:40:41,167 DEBUG MQTT Publishing: emon/emonpi/power2 9
2018-03-12 00:40:41,169 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 13
2018-03-12 00:40:41,170 DEBUG MQTT Publishing: emon/emonpi/vrms 237.39
2018-03-12 00:40:41,172 DEBUG MQTT Publishing: emon/emonpi/t1 25.4
2018-03-12 00:40:41,174 DEBUG MQTT Publishing: emon/emonpi/t2 0
2018-03-12 00:40:41,175 DEBUG MQTT Publishing: emon/emonpi/t3 0
2018-03-12 00:40:41,177 DEBUG MQTT Publishing: emon/emonpi/t4 0
2018-03-12 00:40:41,178 DEBUG MQTT Publishing: emon/emonpi/t5 0
2018-03-12 00:40:41,179 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-03-12 00:40:41,181 DEBUG MQTT Publishing: emon/emonpi/pulsecount 87686
2018-03-12 00:40:41,182 INFO MQTT Publishing: emonhub/rx/5/values 4,9,13,237.39,25.4,0,0,0,0,0,87686
2018-03-12 00:40:44,775 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 2 115 64 8 0 96 175 36 0 42 108 0 137 224 42 68 20 192 44 78 128 (-107)
Yes thatās a float precision issue, itās ugly but it isnāt effecting the data.
in this line is shows the extended ugly floats
but those same values, which do not get explicitly rounded down appear correct as they are passed eg
and
so it is only the printed entry in emonhub.log of the raw list of values that shows the float error which is fine, maybe tidied up later but it isnāt a concern. We do not want to start imposing precision levels just to make the log tidier but I will put it on the snagging list all the same
Paul,
I thought it might be something of that nature since as I mentioned itās not transmitted like that, and MQTT shows it correctly.
Bernie Carter
In relation to ā¦0000001 floating point errors⦠I came across this while finding a solution to an unrelated problem. Interesting to read for those inclined towards understanding binary and float maths.
I smirked at how python uses 3602879701896397 / 2 ** 55 to approximate 0.1
ā15. Floating Point Arithmetic: Issues and Limitations ā Python 3.10.0 documentationā
āpython - Converting a float to a string without rounding it - Stack Overflowā
