Both strike me as odd as I’d expect Active: active (running) in the status but if data is getting to emoncms.org both must be running. Confused!
Did you go through the setup process? Although some of the config will come across, I’d expect some of the system configurations to need updating.
Strictly you do not get any output to the terminal (which in this case, no news is good news). if you then do a ‘status’ command you will see it has been running for a few seconds (i.e. it has just been restarted).
