Hi @borpin, the df -h shows the following:
Filesystem Size Used Avail Use% Mounted on
/dev/root 20G 2.3G 17G 13% /
devtmpfs 481M 0 481M 0% /dev
tmpfs 486M 0 486M 0% /dev/shm
tmpfs 486M 520K 485M 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 486M 0 486M 0% /sys/fs/cgroup
tmpfs 40M 6.6M 34M 17% /var/lib/openhab
tmpfs 1.0M 0 1.0M 0% /var/lib/dhcpcd5
tmpfs 1.0M 8.0K 1016K 1% /var/lib/dhcp
tmpfs 50M 6.2M 44M 13% /var/log
tmpfs 1.0M 0 1.0M 0% /var/tmp
tmpfs 30M 36K 30M 1% /tmp
/dev/mmcblk0p3 3.8G 237M 3.4G 7% /home/pi/data
/dev/mmcblk0p1 60M 22M 39M 37% /boot
/dev/sda2 897G 79M 851G 1% /mnt
So, /var/log at 6.2MB. But when I do du /var/log/ -h, I get 71MB!
0 /var/log/supervisor
4.0K /var/log/mosquitto
8.0K /var/log/logrotate
8.0K /var/log/openhab
4.0K /var/log/mysql
4.0K /var/log/apache2
4.0K /var/log/redis
4.0K /var/log/emonpilcd
65M /var/log/journal/5e3a8d5cbaff427898fd4b9ec446e38e
71M /var/log/
Another topic is that I have noticed the temp files located in /var/cache/man cleaning is failing because the system is read-only. Could this be a source of problems? At this time all files in /var/cache/man are 1.9MB only (du /var/cache/man/ -h).
-Extract of journalctl:
Feb 16 20:02:37 emonpi systemd[1]: Starting Cleanup of Temporary Directories...
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/tr/cat1): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/tr/cat8): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: unlink(/var/cache/man/tr/index.db): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/tr/cat5): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: unlink(/var/cache/man/tr/CACHEDIR.TAG): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: utimensat(/var/cache/man/tr): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/tr): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/cs/cat1): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/cs/cat7): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/cs/cat8): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: unlink(/var/cache/man/cs/index.db): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/cs/cat5): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: unlink(/var/cache/man/cs/CACHEDIR.TAG): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: utimensat(/var/cache/man/cs): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/cs): Read-only file system
Feb 16 20:02:37 emonpi systemd-tmpfiles[6924]: rmdir(/var/cache/man/ru/cat1): Read-only file system
