EmonHub Failing After Update
Hi again Brian,
I’ve been searching for the upgrade to Oct2019 SD image, the how to I mean.
Found some details at https://community.openenergymonitor.org/t/backup-module-usb-import-sh-script-beta/12234/25 , but it seems a few times to relate to problems encountered, rather than a step by step upgrade guide for not so experienced emonpi users. So it makes me a bit unsure about whether I should proceed.
Is there perhaps such a guide available?
Looks like I would need a USB card reader, and also open up the Emonpi case to swap the SD card, right?
Many thanks in advance,
Juerg
Start here Update & Upgrade — OpenEnergyMonitor 0.0.1 documentation and Updating with new SD Card · openenergymonitor/emonpi Wiki · GitHub
and this for the USB import Create new page · openenergymonitor/emonpi Wiki · GitHub although if you can sucessfully make a backup file that usually works just as well.
Yes for the USB method
Yes.
Thank you Brian, I will learn about it and then attempt that at some stage. Cheers
