borpin
(Brian Orpin)
21
At one time we scripted using systemctl edit but creating a dropin, symlinked, means an update to the dropin in GitHub is picked up automatically on a git pull and restarting the service.
Yes. but you suggested the way the scripts did it was wrong, and it isn’t, as it is the lowest level of priority. So when we change this and add in the dropin it will not affect your install.
So what you did as the administrator is correct, what the script does is also correct.
Just disable that Repo from the list
Not really.
