Hello again.
I have had better luck with making user pi and installing from that account.
Again, basic emoncms install was error-free. I left the line install_emonhub=true just hoping that even if it does not get installed, the entries for it to appear in emoncms would be ready.
Installing emonhub using the script these errors occurred:
Defaulting to user installation because normal site-packages is not writeable
Collecting paho-mqtt
Downloading paho-mqtt-1.6.1.tar.gz (99 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 99.4/99.4 KB 2.7 MB/s eta 0:00:00
Preparing metadata (setup.py) ... done
Collecting requests
Downloading requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 KB 27.6 MB/s eta 0:00:00
Collecting pybluez
Downloading PyBluez-0.23.tar.gz (97 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 97.6/97.6 KB 16.2 MB/s eta 0:00:00
Preparing metadata (setup.py) ... error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [1 lines of output]
error in PyBluez setup command: use_2to3 is invalid.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
I “solved” it (maybe) by apt install python3-requests python3-paho-mqtt
Then the systemd issue is solved by changing these:
Requires=rsyslog.service
After=network.target
plus the obligatory sudo systemctl daemon-reload.
Then emonhub will start! And, after adding user pi to the group dialout on the guest CT, and some fiddling with /dev/ttyUSB0 on Proxmox host ( chown 100000:100020 /dev/ttyUSB0 ), and modifying the CT config file on the Proxmox host to end with
lxc.cgroup2.devices.allow: c 188:00 rwm
lxc.mount.entry: /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file
and restarting it of course. YMMV, but this is working for my set up.
Notably, the entry for emonhub does NOT appear in emoncms webconfig settings. I’m not sure if that is expected or not. So I modified the emonhub config file commenting out things I don’t use and adding my emonTx4 with USB connection as directed:
[interfacers]
### Manually added for the emonTx4 unit
[[USB]]
Type = EmonHubOEMInterfacer
[[[init_settings]]]
com_port = /dev/ttyUSB0
com_baud = 115200
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
nodename = emonTx4
when I tail the emonhub.log I see what looks like correct functionality:
2023-08-24 12:44:37,155 DEBUG USB Report 248 AC present V1 = 240.61 V2 = 0.00 V3 = 0.00 f=50.02
2023-08-24 12:44:37,357 DEBUG USB Ch 1 I=0.048 W=0 VA=11 Wh=0 pf=0.0087
2023-08-24 12:44:37,458 DEBUG USB Ch 2 I=0.045 W=0 VA=11 Wh=0 pf=-0.0658
2023-08-24 12:44:37,559 DEBUG USB Ch 3 I=0.023 W=0 VA=5 Wh=0 pf=-0.0418
2023-08-24 12:44:37,660 DEBUG USB Ch 4 I=0.022 W=0 VA=5 Wh=0 pf=-0.0647
2023-08-24 12:44:37,762 DEBUG USB Ch 5 I=0.022 W=0 VA=5 Wh=0 pf=-0.0074
2023-08-24 12:44:37,863 DEBUG USB Ch 6 I=0.009 W=0 VA=2 Wh=0 pf=-0.0083
2023-08-24 12:44:37,964 DEBUG USB Ch 7 I=0.009 W=0 VA=2 Wh=0 pf=-0.0757
2023-08-24 12:44:38,065 DEBUG USB Ch 8 I=0.009 W=0 VA=2 Wh=0 pf=-0.0303
2023-08-24 12:44:38,166 DEBUG USB Ch 9 I=0.010 W=0 VA=2 Wh=0 pf=0.0056
2023-08-24 12:44:38,268 DEBUG USB Ch 10 I=0.008 W=0 VA=2 Wh=0 pf=-0.0107
2023-08-24 12:44:38,369 DEBUG USB Ch 11 I=0.009 W=0 VA=2 Wh=0 pf=-0.0496
2023-08-24 12:44:38,471 DEBUG USB Ch 12 I=0.009 W=0 VA=2 Wh=0 pf=-0.0670
2023-08-24 12:44:46,312 DEBUG USB RF No Ack (1)
2023-08-24 12:44:46,815 DEBUG USB RF No Ack (2)
2023-08-24 12:44:46,917 DEBUG USB Report 249 AC present V1 = 240.75 V2 = 0.00 V3 = 0.00 f=49.91
2023-08-24 12:44:47,118 DEBUG USB Ch 1 I=0.047 W=0 VA=11 Wh=0 pf=-0.0042
2023-08-24 12:44:47,219 DEBUG USB Ch 2 I=0.045 W=0 VA=11 Wh=0 pf=-0.0708
2023-08-24 12:44:47,321 DEBUG USB Ch 3 I=0.022 W=0 VA=5 Wh=0 pf=-0.0344
2023-08-24 12:44:47,422 DEBUG USB Ch 4 I=0.022 W=0 VA=5 Wh=0 pf=-0.0690
2023-08-24 12:44:47,523 DEBUG USB Ch 5 I=0.022 W=0 VA=5 Wh=0 pf=0.0028
2023-08-24 12:44:47,624 DEBUG USB Ch 6 I=0.009 W=0 VA=2 Wh=0 pf=-0.0306
2023-08-24 12:44:47,725 DEBUG USB Ch 7 I=0.009 W=0 VA=2 Wh=0 pf=-0.0747
2023-08-24 12:44:47,827 DEBUG USB Ch 8 I=0.009 W=0 VA=2 Wh=0 pf=-0.0113
2023-08-24 12:44:47,928 DEBUG USB Ch 9 I=0.009 W=0 VA=2 Wh=0 pf=-0.0614
2023-08-24 12:44:48,029 DEBUG USB Ch 10 I=0.009 W=0 VA=2 Wh=0 pf=0.0096
2023-08-24 12:44:48,130 DEBUG USB Ch 11 I=0.008 W=0 VA=2 Wh=0 pf=-0.0672
2023-08-24 12:44:48,231 DEBUG USB Ch 12 I=0.009 W=0 VA=2 Wh=0 pf=-0.0681
(I haven’t connected the CT clamps to anything yet)
The docs say that once this is done I will see the sensors from the emonTx4 automatically populate in the INPUTS area of emoncms webconfig – but I don’t!
Maybe I should take that to a new thread. I did here.
When I look in emoncms ‘System Info’ I see the following services are green and happy:
emonhub
emoncms_mqtt
feedwriter
service-runner
redis-server
mosquitto
demandshaper
and emonPiLCD “not found or not installed”
Please let me know if you have any suggestions and thanks for bearing with me.
