Emon Tx V4 and 433MHz Radio Formats
[Image added to Emon Tx V4 and 433MHz Radio Formats - #36 by Robert.Wall]
@Robert.Wall
Thank you for the emonTH photograph :smiley:
The emonTH is running with rfm69TxLib using the ā€˜native’ message format.
If anyone requires it, it should be easy enough to make the RFM12B transmit using the LPL message format, with a moderately simple change to rfmTxLib, but transmit power will be fixed and it won’t participate in the automatic power reduction nor will it re-transmit a failed message (because it doesn’t receive at all and so will ignore the request).
I’ve added a firmware and configuration page to the emonPi documentation, mirroring the same layout/format as seen in the emonTx3 documentation:
Once Im happy that the documentation and releases are all in place I will do a proper forum announcement.
Credit to @Robert.Wall for most of the work behind this. Robert built the JeeLib Native firmwares and produced the associated configuration documentation. I’ve just made a set of relatively small modifications to enable the use of the LowPowerLabs format and adjusted the configuration documentation a little to reflect this.
There are a couple of things that I need to look at again for serial configuration consistency.
I disabled the ability to change a temperature sensor’s address or position in both the emonTx4 and emonTx3 firmwares (it’s still available in the emonPi_CM firmware). I also changed the api for turning temperature sensing on or off. This resulted from changing the way the serial configuration in parsed, I added more strict checking of command and parameter lengths - but I would like to look at this again as Im sure there’s a way to achieve both and keep a consistent api throughout.
I’ve combined the LowPowerLabs emonTh2 firmware with the jeelib native and classic variants so that there is only a single firmware to maintain. The latest version is 4.1.0 and is available in the main emonth2 repository here: https://github.com/openenergymonitor/emonth2/tree/master/firmware. Again mostly Roberts work on the rfm69n version, I’ve just added #defines to switch between the radio formats, and a #define for ATTINY support.
Latest release: Release 4.1.0 Ā· openenergymonitor/emonth2 Ā· GitHub
Documentation firmware page: Firmware — OpenEnergyMonitor 0.0.1 documentation
Documentation configuration page: Configuration — OpenEnergyMonitor 0.0.1 documentation
Again I will do a proper announcement again, after completing the remaining firmwares.
In the interfacer?
[edit]
Lets not forget those poor folk on a emonTH1 :upside_down_face: (it still works :slight_smile: )
How about a top level section for Connecting it Together - can’t think of a better title - there must be one :slight_smile:
In this include
  • RFM (the current Networking)
  • Direct Serial (UART)
  • Direct Serial (USB)
  • Wi-Fi Modules
There is probably quite a bit of duplication, so this could bring that all together.
Just a thought
not forgotten! :slight_smile:
no in the sketch itself.
Yes great, will have a think about this.
How about Interoperability?
I’ve been looking at firmware for my emonTH and have just installed Platformio.
I’ve been looking at the Using Platformio page, a couple of observations:
  1. The page says it is built on the Atom editor but Platformio’s own pages clearly aim at VS Code first.
  2. The link to silabs drivers gives a 404 error, I think it needs this one but can someone check please?
Thanks!
Hello @christian I only use platformio as a command line tool on linux, which it works very well at. There is an old platformio guide with windows instructions here - it probably needs updating? Using PlatformIO — OpenEnergyMonitor 0.0.1 documentation
Thanks; my points relate to 2 inaccuracies on that page, it needs updating but I don’t believe I have permission.
This link takes you straight to the driver download:
I strongly advise using the Arduino IDE (search here for my posts about Platformio if you need details of my reasons for not using platformio). In ā€˜Learn’, you will find all the details of the libraries and driver installation that you need (for Windoze, Linux & Mac).
https://docs.openenergymonitor.org/electricity-monitoring/arduino-ide/index.html
Ah good find. Someone needed these recently for connecting a TX4 by USB and I couldn’t find the right page with the link (which is Obs broken.
@TrystanLea something for the TX4 page as well.
@Gwil or @TrystanLea
Some unclickable links on Installing the Arduino IDE – Windows 10 — OpenEnergyMonitor 0.0.1 documentation
I’ve updated the emonTh1 firmware with the option to switch between jeelib classic and lowpowerlabs. Here’s the release with hex files: Release 2.8.0 Ā· openenergymonitor/emonTH Ā· GitHub. These are also available via the emoncms update mechanism.
@Robert.Wall thanks will take a look at those
Hi everyone, thanks you for your great job on new device firmware and the material that you build. I have created a PR to fix an error in the emonTH2 firmware (when another frequency is used). I have also opened an issue (with a link to a commit) about the implementation of a new feature that it allows the possibility to use another encryption key (without modifying the source code). Don’t hesitate to comment it :grinning:
