Electricity meters with HAN interface
Ah, thanks. I’d probably hack one of the little perl scripts I use for interfacing everything else then. I’ll be interested to hear whether it all works well when you get it set up. Might be a reason to get a smart meter once the alt-HAN stuff is widely available.
Hi @nchaveiro , also here a user from Portugal.
I was investigating and this
seems the way out to read the Portuguese electricity distributor power meter HAN interface.
Or have you found a way out? If yes, can you share?
Thanks a lot.
Hi Nuno, for Portugal the puzzle is solved.
I’ve done my own ‘EDP box’ device that plugs on the meter and use a customized tasmota script to post directly via WIFI to emoncms. If interested i can share.
See the links :
Some photo of the HAN Wifi Modules I’ve assembled:
It work with any modbus device
