boelle
(Bo Herrmannsen)
21
maybe @TrystanLea or @glyn.hudson knows how to crack this nut
OK. The reason I asked is that your picture shows the data value as 99.999 in feeds 8 through 12 as well as feed 7. So youâre saying that feeds 8 through 12 contain data values less than 80 as well as more than 80?
boelle
(Bo Herrmannsen)
23
the pic show feed 7 selected⊠so its only showing for feed 7 not the others
boelle
(Bo Herrmannsen)
24
but to answer⊠yes the other feeds have data that could be anything
the only common in all 6 feeds is the time collum
Got it.
If you know the range of the timestamps, you can specify that.
boelle
(Bo Herrmannsen)
26
a range is only good if its all false data in that rangeâŠ
Making sure weâre on the sam sheet of musicâŠ
Do you wanât to zap ALL of feeds 8 through 12 or just parts of them?
boelle
(Bo Herrmannsen)
28
only parts
i want to zap in feeds 8 to 12 that has the time value that we get from feed 7
Got it. If memory serves, thatâll take a ânestedâ select clause.
Something along the lines of:
DELETE FROM mytable1 WHERE value IN (SELECT key FROM mytable2 WHERE <filtering_condition>)
Ref:
Again, something similar to that, as opposed to that exact syntax.
I think this is what youâre looking for:
The only difference being your timestamp will come from the same table.
boelle
(Bo Herrmannsen)
31
i googled and asked a bit arround and yes the answer is close enough
SELECT * FROM feed_7 f7 LEFT JOIN feed_8 f8 ON f8.time = f7.time LEFT JOIN feed_9 f9 ON f9.time = f7.time LEFT JOIN feed_10 f10 ON f10.time = f7.time LEFT JOIN feed_11 f11 ON f11.time = f7.time LEFT JOIN feed_12 f12 ON f12.time = f7.time WHERE f7.data > 80
boelle
(Bo Herrmannsen)
33
and to do the actual delete
DELETE f7, f8, f9, f10, f11, f12
FROM feed_7 f7
WHERE f7.data > 80
Good deal. Thanks for sharing that.
boelle
(Bo Herrmannsen)
35
and i found wrong values in feed_8 too, ie over 80 degrees
so i rewrote it to
FROM feed_8 f8
LEFT JOIN feed_7 f7 ON f7.time = f8.time
LEFT JOIN feed_9 f9 ON f9.time = f8.time
LEFT JOIN feed_10 f10 ON f10.time = f8.time
LEFT JOIN feed_11 f11 ON f11.time = f8.time
LEFT JOIN feed_12 f12 ON f12.time = f8.time
WHERE f8.data > 80
does that look about right?
Have you ran the first one yet?
Then Iâd say the second one ought to be OK too.
boelle
(Bo Herrmannsen)
39
and i have equal amount of records in all 6 feeds, so must be right
