Written to disk, no longer just in RAM, Redis or Buffer etc, actually written to disk.
Looks like that is right too.
When posting using the buffered-write though, the usual phpfina “post()” function isn’t used.
When the input process calls feed->insert_data it checks for redisbuffer enabled (feed_model.php L814) and uses redisbuffer->post() and not phpfina->post() for low-write installs.
In that instance post() just adds the details to a buffer and then periodically, the bufferedwrite service calls redisbuffer->process_buffers() which in turn calls redisbuffer->process_feed_buffer(). Which (and I’m a little hazy here) I believe will ordinarily call phpfina->post_bulk_prepare(). Which appears to check if ($pos>$last_pos) and only writes the data if the data is later than the last recorded data (not equal to).
further down that code, the “else” says "if data is in past, its not supported, … ".
The code is pretty complex so I wouldn’t be at all surprised if I’ve got something not quite right.
A lot of it revolves around what $last_pos actually is. I had arrived at the conclusion that the minus one in the $last_pos = $meta->npoints - 1; lines is just to derive an index from a count eg a count of 3, minus 1, gives us an index of 2 as in 0,1,2 is a count of 3.
