CT Accuracy / Calibration
When the inverter is matching the house load you’ll probably find the CT is left measuring a very distorted load. The inverter is likely supplying the fundamental and leaving the grid to supply all the harmonics. You can see what my whole-house CT sees under those conditions here. and again in the post immediately after that one.
