Bridge 2 MQTT Brokers and rename topics
Yes, i’m editing settings.ini
after setting emoncms log level to 1
the emoncms log is a constant stream of mqtt messages
2023-10-05 13:10:22.052|INFO|emoncms_mqtt.php|emon/inverter_1/pv_power/state 232
2023-10-05 13:10:22.063|INFO|emoncms_mqtt.php|emon/inverter_1/battery_voltage/state 27.4
2023-10-05 13:10:22.074|INFO|emoncms_mqtt.php|emon/inverter_1/load_apparent_power/state 165
2023-10-05 13:10:22.085|INFO|emoncms_mqtt.php|emon/inverter_1/pv_current_2/state 1.4
2023-10-05 13:10:22.096|INFO|emoncms_mqtt.php|emon/inverter_1/temperature/state 33.0
2023-10-05 13:10:22.107|INFO|emoncms_mqtt.php|emon/inverter_1/load_percentage/state 4
2023-10-05 13:10:22.118|INFO|emoncms_mqtt.php|emon/inverter_1/battery_current/state 5.0
2023-10-05 13:10:22.129|INFO|emoncms_mqtt.php|emon/inverter_1/grid_power/state 0
2023-10-05 13:10:22.140|INFO|emoncms_mqtt.php|emon/inverter_1/pv_voltage_1/state 1.4
2023-10-05 13:10:22.150|INFO|emoncms_mqtt.php|emon/inverter_1/pv_voltage_2/state 166.0
2023-10-05 13:10:22.161|INFO|emoncms_mqtt.php|emon/inverter_1/pv_power_1/state 0
2023-10-05 13:10:22.172|INFO|emoncms_mqtt.php|emon/inverter_1/device_mode/state Solar/Battery
2023-10-05 13:10:22.184|INFO|emoncms_mqtt.php|emon/inverter_1/grid_voltage/state 2.0
2023-10-05 13:10:22.195|INFO|emoncms_mqtt.php|emon/inverter_1/ac_output_frequency/state 49.9
2023-10-05 13:10:22.205|INFO|emoncms_mqtt.php|emon/inverter_1/ac_output_voltage/state 229.0
2023-10-05 13:10:22.216|INFO|emoncms_mqtt.php|emon/inverter_1/load_power/state 165
2023-10-05 13:10:22.227|INFO|emoncms_mqtt.php|emon/inverter_1/pv_power_2/state 232
2023-10-05 13:10:22.238|INFO|emoncms_mqtt.php|emon/battery_1/current/state 5.0
2023-10-05 13:10:22.248|INFO|emoncms_mqtt.php|emon/battery_1/power/state 137
2023-10-05 13:10:22.259|INFO|emoncms_mqtt.php|emon/battery_1/state_of_charge/state 100
2023-10-05 13:10:22.271|INFO|emoncms_mqtt.php|emon/battery_1/voltage/state 27.4
2023-10-05 13:10:22.282|INFO|emoncms_mqtt.php|emon/total/battery_power/state 137
2023-10-05 13:10:22.293|INFO|emoncms_mqtt.php|emon/total/battery_state_of_charge/state 100
2023-10-05 13:10:24.-418|INFO|emoncms_mqtt.php|emon/inverter_1/grid_frequency/state 46.0
2023-10-05 13:10:24.-257|INFO|emoncms_mqtt.php|emon/inverter_1/pv_current_1/state 0.0
2023-10-05 13:10:24.-246|INFO|emoncms_mqtt.php|emon/inverter_1/pv_power/state 232
2023-10-05 13:10:24.-234|INFO|emoncms_mqtt.php|emon/inverter_1/battery_voltage/state 27.4
2023-10-05 13:10:24.-224|INFO|emoncms_mqtt.php|emon/inverter_1/load_apparent_power/state 167
2023-10-05 13:10:24.-213|INFO|emoncms_mqtt.php|emon/inverter_1/pv_current_2/state 1.4
2023-10-05 13:10:24.-202|INFO|emoncms_mqtt.php|emon/inverter_1/temperature/state 33.0
2023-10-05 13:10:24.-192|INFO|emoncms_mqtt.php|emon/inverter_1/load_percentage/state 4
2023-10-05 13:10:24.-181|INFO|emoncms_mqtt.php|emon/inverter_1/battery_current/state 5.0
2023-10-05 13:10:24.-170|INFO|emoncms_mqtt.php|emon/inverter_1/grid_power/state 0
2023-10-05 13:10:24.-159|INFO|emoncms_mqtt.php|emon/inverter_1/pv_voltage_1/state 1.4
2023-10-05 13:10:24.-149|INFO|emoncms_mqtt.php|emon/inverter_1/pv_voltage_2/state 166.0
2023-10-05 13:10:24.-135|INFO|emoncms_mqtt.php|emon/inverter_1/pv_power_1/state 0
2023-10-05 13:10:24.-124|INFO|emoncms_mqtt.php|emon/inverter_1/device_mode/state Solar/Battery
2023-10-05 13:10:24.-114|INFO|emoncms_mqtt.php|emon/inverter_1/grid_voltage/state 2.0
2023-10-05 13:10:24.-103|INFO|emoncms_mqtt.php|emon/inverter_1/ac_output_frequency/state 49.9
2023-10-05 13:10:24.-92|INFO|emoncms_mqtt.php|emon/inverter_1/ac_output_voltage/state 230.0
2023-10-05 13:10:24.-82|INFO|emoncms_mqtt.php|emon/inverter_1/load_power/state 167
2023-10-05 13:10:24.-71|INFO|emoncms_mqtt.php|emon/inverter_1/pv_power_2/state 232
2023-10-05 13:10:24.-60|INFO|emoncms_mqtt.php|emon/battery_1/current/state 5.0
2023-10-05 13:10:24.-49|INFO|emoncms_mqtt.php|emon/battery_1/power/state 137
2023-10-05 13:10:24.-39|INFO|emoncms_mqtt.php|emon/battery_1/state_of_charge/state 100
2023-10-05 13:10:24.-28|INFO|emoncms_mqtt.php|emon/battery_1/voltage/state 27.4
2023-10-05 13:10:24.-17|INFO|emoncms_mqtt.php|emon/total/battery_power/state 137
OK, so are you sure these are not appearing on the inputs page?
nope
@TrystanLea - I am out of ideas. The script seems to be picking it up from MQTT but they are not appearing.
@Ashipa - have you checked the syslog? (journalctl -f) odd things can appear there.
$ journalctl -f
Oct 05 13:27:53 fountain systemd[1]: demandshaper.service: Failed with result 'exit-code'.
Oct 05 13:27:55 fountain systemd[1]: emonhub.service: Scheduled restart job, restart counter is at 210.
Oct 05 13:27:55 fountain systemd[1]: Stopped emonHub data multiplexer.
Oct 05 13:27:55 fountain systemd[1]: Starting emonHub data multiplexer...
Oct 05 13:27:55 fountain systemd[3486]: emonhub.service: Failed to determine user credentials: No such process
Oct 05 13:27:55 fountain systemd[3486]: emonhub.service: Failed at step USER spawning /bin/mkdir: No such process
Oct 05 13:27:55 fountain systemd[1]: emonhub.service: Control process exited, code=exited, status=217/USER
Oct 05 13:27:55 fountain systemd[1]: emonhub.service: Failed with result 'exit-code'.
Oct 05 13:27:55 fountain systemd[1]: Failed to start emonHub data multiplexer.
Oct 05 13:27:58 fountain systemd[1]: run-docker-runtime\x2drunc-moby-717ff4a53101d9d546a10baeadc1487ecc2f763763db099af88c0ad8b824870e-runc.AyNGoX.mount: Deactivated successfully.
Oct 05 13:28:00 fountain systemd[1]: emonhub.service: Scheduled restart job, restart counter is at 211.
Oct 05 13:28:00 fountain systemd[1]: Stopped emonHub data multiplexer.
Oct 05 13:28:00 fountain systemd[1]: Starting emonHub data multiplexer...
Oct 05 13:28:00 fountain systemd[3512]: emonhub.service: Failed to determine user credentials: No such process
Oct 05 13:28:00 fountain systemd[3512]: emonhub.service: Failed at step USER spawning /bin/mkdir: No such process
Oct 05 13:28:00 fountain systemd[1]: emonhub.service: Control process exited, code=exited, status=217/USER
Oct 05 13:28:00 fountain systemd[1]: emonhub.service: Failed with result 'exit-code'.
Oct 05 13:28:00 fountain systemd[1]: Failed to start emonHub data multiplexer.
Oct 05 13:28:05 fountain systemd[1]: emonhub.service: Scheduled restart job, restart counter is at 212.
Oct 05 13:28:05 fountain systemd[1]: Stopped emonHub data multiplexer.
Oct 05 13:28:05 fountain systemd[1]: Starting emonHub data multiplexer...
Oct 05 13:28:05 fountain systemd[3514]: emonhub.service: Failed to determine user credentials: No such process
Oct 05 13:28:05 fountain systemd[3514]: emonhub.service: Failed at step USER spawning /bin/mkdir: No such process
Oct 05 13:28:05 fountain systemd[1]: emonhub.service: Control process exited, code=exited, status=217/USER
Oct 05 13:28:05 fountain systemd[1]: emonhub.service: Failed with result 'exit-code'.
Oct 05 13:28:05 fountain systemd[1]: Failed to start emonHub data multiplexer.
Oct 05 13:28:10 fountain systemd[1]: emonhub.service: Scheduled restart job, restart counter is at 213.
Oct 05 13:28:10 fountain systemd[1]: Stopped emonHub data multiplexer.
Oct 05 13:28:10 fountain systemd[1]: Starting emonHub data multiplexer...
Oct 05 13:28:10 fountain systemd[3516]: emonhub.service: Failed to determine user credentials: No such process
Oct 05 13:28:10 fountain systemd[3516]: emonhub.service: Failed at step USER spawning /bin/mkdir: No such process
Oct 05 13:28:10 fountain systemd[1]: emonhub.service: Control process exited, code=exited, status=217/USER
Oct 05 13:28:10 fountain systemd[1]: emonhub.service: Failed with result 'exit-code'.
Oct 05 13:28:10 fountain systemd[1]: Failed to start emonHub data multiplexer.
Oct 05 13:28:16 fountain systemd[1]: emonhub.service: Scheduled restart job, restart counter is at 214.
Oct 05 13:28:16 fountain systemd[1]: Stopped emonHub data multiplexer.
Oct 05 13:28:16 fountain systemd[1]: Starting emonHub data multiplexer...
Oct 05 13:28:16 fountain systemd[3517]: emonhub.service: Failed to determine user credentials: No such process
Oct 05 13:28:16 fountain systemd[3517]: emonhub.service: Failed at step USER spawning /bin/mkdir: No such process
Oct 05 13:28:16 fountain systemd[1]: emonhub.service: Control process exited, code=exited, status=217/USER
Oct 05 13:28:16 fountain systemd[1]: emonhub.service: Failed with result 'exit-code'.
Oct 05 13:28:16 fountain systemd[1]: Failed to start emonHub data multiplexer.
BTW, I’d slow this down. Every 2 seconds is a bit excessive and can overload the emoncms end. Once every 10 is quick enough, I’d suggest.
Unrelated (I suspect), but you want to stop and disable these 2 services.
Yeah , was going to ask if its safe to disable them.
where do i set the time intervals for the MQTT?
I think you said Solar Assistant was running on a Pi? Can you control the rate from there (MQTT is a dumb system in this respect).
No. there’s aren’t any settings on that end other than username/password
@borpin thank you very much for the assistance.
I really appreciate the time and patience.
I nuked the OS install and started from scratch again.
This time around I followed the script installation down to a tee.
Put in the bridge .conf
And voila, the inputs appeared.
In summary, I have no idea what was wrong initially, but it’s sorted now after doing a clean os install and fresh setup + the bridge.
Didn’t have to fudge with any settings… Yet
I don’t know which post to mark as solution.
Maybe the correct bridge…conf post.
No bother. Glad you got it sorted.
On the first install, did you use the user Pi?
No I did not.
Even this install I used my Ubuntu username.
But I did not change the host name in the script.
It remains emonpi
