Would it be possible to do a release / module info for this repo as well? When helping users it would be good to know what version that is sitting at as well as everything else.
It has a tag: Release 1.0.4-beta · openenergymonitor/EmonScripts · GitHub
Yes but that isn’t visible in the admin page.
It just started to be an issue within the last month. Difficult to point to a day. Looks like the update script is running and updating things. With the last run on May 25.
Git:
	URL :	 https://github.com/emoncms/emoncms.git
	Branch :	 * stable
	Describe :	 10.1.11-7-g90f39158
Yes. I use node-red on the remote Dakboard machine to read a motion sensor and turn off the Dakboard monitor when no one is in the room, and to format some of the solar and use data for display on the Dakboard.
At the moment I do. My emonCMS server is on the internet, handling traffic on port 80 and doing a reverse proxy to emonCMS and a few other internal servers. My home setup grew up around my emonCMS Pi, which is the reason this particular machine is the proxy server. I could divide that out to a separate Pi, but haven’t gotten around to it. So as things stand, the way I understand internet security, it is best to have ufw in place.
I will take a look at that. I tried disabling some of the things I knew to be requesting data from the emonCMS server, and the blocked requests kept rolling in. So there is something I put in place that I’m forgetting, or ufw is logging a blocked request even while my server is responding and things seem to be working otherwise.
My initial thought it is that (Port 1880).
Check you update logs, it should be on 10.2.3. It is only a manual update process for emoncms.
Update: The cause of apache2 going down was certbot. It was random because certbot tries to run at random intervals to distribute the timing of requests to their servers. The certbot service tries to use “apachectl -k start” to restart apache, and for some reason this doesn’t work, even though “systemctl start apache2” does work when I do so manually. Still investigating that here: Apache2 does not come back up, certbot finishes abnormally - #9 by brandock - Help - Let's Encrypt Community Support
In the meantime, /var/log is full again, and I could still use some help figuring out how to handle this situation. One strategy is to try to calm down the logging of Letsencrypt certbot and ufw, and I’m working on that, but shouldn’t the log rotating be able to handle the volume?
pi@emonpi:~$ sudo find /var/log -type f -exec du -ah {} + | sort -n -r | head -n 20
456K	/var/log/letsencrypt/letsencrypt.log
444K	/var/log/ufw.log
288K	/var/log/lastlog
256K	/var/log/auth.log
220K	/var/log/daemon.log
112K	/var/log/wtmp
112K	/var/log/logrotate/logrotate.log.1
72K	/var/log/messages
72K	/var/log/kern.log
40K	/var/log/syslog
28K	/var/log/apt/eipp.log.xz
24K	/var/log/logrotate/logrotate.log
24K	/var/log/faillog
12K	/var/log/emonhub/emonhub.log
12K	/var/log/emoncms/emonpiupdate.log
8.0K	/var/log/logrotate/logrotate.log.7.gz
8.0K	/var/log/logrotate/logrotate.log.5.gz
8.0K	/var/log/logrotate/logrotate.log.2.gz
8.0K	/var/log/emonpilcd/emonpilcd.log
4.0K	/var/log/wifiAP.log
pi@emonpi:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       4.0G  2.9G  949M  76% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           464M     0  464M   0% /dev/shm
tmpfs           464M   12M  452M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
tmpfs            30M     0   30M   0% /tmp
tmpfs           1.0M     0  1.0M   0% /var/lib/php/sessions
tmpfs           1.0M     0  1.0M   0% /var/tmp
/dev/mmcblk0p3   10G  1.2G  8.4G  12% /var/opt/emoncms
/dev/mmcblk0p1  253M   53M  200M  21% /boot
log2ram          50M   50M     0 100% /var/log
tmpfs            93M     0   93M   0% /run/user/1000
pi@emonpi:~$ ls -lh --size /var/log
total 1.6M
   0 -rw-r--r-- 1 root      root       0 Dec  1 00:00 alternatives.log
   0 drwxr-x--- 2 root      adm      100 Nov 17  2019 apache2
   0 drwxr-xr-x 2 root      root     100 Dec  1 00:00 apt
256K -rw-r----- 1 root      adm     256K May 29 08:55 auth.log
   0 -rw-r--r-- 1 root      root       0 Sep 25  2019 bootstrap.log
4.0K -rw-rw---- 1 root      utmp    2.3K May 29 08:45 btmp
220K -rw-r----- 1 root      adm     220K May 29 08:48 daemon.log
4.0K -rw-r----- 1 root      adm     2.9K May 28 21:48 debug
   0 -rw-r--r-- 1 root      root       0 Dec  1 00:00 dpkg.log
   0 drwxr-xr-x 2 pi        root     160 May 28 23:17 emoncms
   0 drwxrwxr-x 2 root      emonhub   60 Oct 17  2019 emonhub
   0 drwxr-xr-x 2 pi        root      60 Oct 17  2019 emonpilcd
 24K -rw-r--r-- 1 root      root     24K Oct 17  2019 faillog
 72K -rw-r----- 1 root      adm      70K May 28 21:48 kern.log
288K -rw-rw-r-- 1 root      utmp    286K May 29 08:45 lastlog
   0 -rw-r--r-- 1 root      root       0 May 26 21:27 lastlog.log
   0 drwx------ 2 root      root      60 May 27 21:57 letsencrypt
4.0K -rw-r--r-- 1 root      root    2.5K May 29 08:17 log2ram.log
   0 drwxr-xr-x 2 root      adm      220 May 29 08:17 logrotate
   0 -rw-r--r-- 1 root      root       0 May 26 21:28 logrotate.log.1
 72K -rw-r----- 1 root      adm      72K May 29 08:55 messages
   0 drwxr-xr-x 2 mosquitto root      60 Oct 17  2019 mosquitto
   0 drwxr-s--- 2 mysql     adm       60 May 29 00:17 mysql
   0 drwx------ 2 root      root      40 Sep 25  2019 private
   0 drwxr-s--- 2 redis     adm       60 May 27 00:00 redis
   0 lrwxrwxrwx 1 root      root      12 Oct 17  2019 rotated_logs -> /var/log.old
 44K -rw-r----- 1 root      adm      44K May 29 08:55 syslog
444K -rw-r----- 1 root      adm     444K May 29 08:55 ufw.log
4.0K -rw-r----- 1 root      adm      570 May 28 21:48 user.log
4.0K -rw-r--r-- 1 root      root    1.1K May 28 21:48 wifiAP.log
112K -rw-rw-r-- 1 root      utmp    110K May 29 08:45 wtmp
pi@emonpi:~$
Here is the output of testing logrotate.
pi@emonpi:~$ sudo /usr/sbin/logrotate -v /etc/logrotate.conf
reading config file /etc/logrotate.conf
including /etc/logrotate.d
reading config file 00_defaults
reading config file 00_olddir
olddir is now /var/log.old
reading config file alternatives
reading config file apache2
reading config file apt
reading config file btmp
reading config file certbot
reading config file dpkg
reading config file emoncms
olddir is now /var/log.old/emoncms
reading config file emonhub
olddir is now /var/log.old/emonhub
reading config file log2ram
reading config file mosquitto
reading config file mysql-server
reading config file redis-server
reading config file rsyslog
reading config file ufw
reading config file wtmp
Reading state from file: /var/lib/logrotate/status
Allocating hash table for state file, size 64 entries
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Creating new state
Handling 18 logs
rotating pattern: /var/log/logrotate/*.log  102400 bytes (7 rotations)
empty log files are not rotated, log files >= 512000 are rotated earlier, old logs are removed
considering log /var/log/logrotate/logrotate.log
  Now: 2020-05-29 09:08
  Last rotated at 2020-05-24 00:00
  log does not need rotating (log size is below the 'size' threshold)
rotating pattern: /var/log/alternatives.log  monthly (12 rotations)
olddir is /var/log.old, empty log files are not rotated, log files >= 512000 are rotated earlier, old logs are removed
considering log /var/log/alternatives.log
  Last rotated at 2019-12-01 00:00
  log does not need rotating (log is empty)
rotating pattern: /var/log/apache2/*.log  after 1 days (14 rotations)
considering log /var/log/apache2/access.log
  Last rotated at 2019-11-16 22:00
considering log /var/log/apache2/error.log
  Last rotated at 2019-11-17 00:00
considering log /var/log/apache2/other_vhosts_access.log
not running prerotate script, since no logs will be rotated
not running postrotate script, since no logs were rotated
rotating pattern: /var/log/apt/term.log  monthly (12 rotations)
considering log /var/log/apt/term.log
rotating pattern: /var/log/apt/history.log  monthly (12 rotations)
considering log /var/log/apt/history.log
rotating pattern: /var/log/btmp  monthly (1 rotations)
olddir is /var/log.old, empty log files are rotated, log files >= 512000 are rotated earlier, old logs are removed
considering log /var/log/btmp
  Last rotated at 2020-05-01 00:00
  log does not need rotating (log has been rotated at 2020-5-1 0:0, that is not month ago yet)
rotating pattern: /var/log/letsencrypt/*.log  weekly (12 rotations)
considering log /var/log/letsencrypt/letsencrypt.log
  log does not need rotating (log has been rotated at 2020-5-24 0:0, that is not week ago yet)
rotating pattern: /var/log/dpkg.log  monthly (12 rotations)
considering log /var/log/dpkg.log
rotating pattern: /var/log/emoncms/*.log  weekly (4 rotations)
olddir is /var/log.old/emoncms, empty log files are rotated, log files >= 3145728 are rotated earlier, old logs are removed
considering log /var/log/emoncms/apache2-error.log
considering log /var/log/emoncms/emoncms.log
considering log /var/log/emoncms/emonpiupdate.log
considering log /var/log/emoncms/emonupdate.log
considering log /var/log/emoncms/importbackup.log
considering log /var/log/emoncms/wificheck.log
rotating pattern: /var/log/emonhub/emonhub.log  weekly (4 rotations)
olddir is /var/log.old/emonhub, empty log files are rotated, log files >= 3145728 are rotated earlier, old logs are removed
considering log /var/log/emonhub/emonhub.log
rotating pattern: /var/log/log2ram.log
 after 1 days (7 rotations)
considering log /var/log/log2ram.log
  Last rotated at 2020-05-29 00:00
  log does not need rotating (log has been rotated at 2020-5-29 0:0, that is not day ago yet)
rotating pattern: /var/log/mosquitto/mosquitto.log  102400 bytes (7 rotations)
considering log /var/log/mosquitto/mosquitto.log
rotating pattern: /var/log/mysql/mysql.log /var/log/mysql/mysql-slow.log /var/log/mysql/mariadb-slow.log /var/log/mysql/error.log  after 1 days (7 rotations)
considering log /var/log/mysql/mysql.log
  log /var/log/mysql/mysql.log does not exist -- skipping
considering log /var/log/mysql/mysql-slow.log
  log /var/log/mysql/mysql-slow.log does not exist -- skipping
considering log /var/log/mysql/mariadb-slow.log
  log /var/log/mysql/mariadb-slow.log does not exist -- skipping
considering log /var/log/mysql/error.log
rotating pattern: /var/log/redis/redis-server*.log  weekly (12 rotations)
considering log /var/log/redis/redis-server.log
  Last rotated at 2020-05-27 00:00
  log does not need rotating (log has been rotated at 2020-5-27 0:0, that is not week ago yet)
rotating pattern: /var/log/syslog
considering log /var/log/syslog
rotating pattern: /var/log/mail.info
/var/log/mail.warn
/var/log/mail.err
/var/log/mail.log
/var/log/daemon.log
/var/log/kern.log
/var/log/auth.log
/var/log/user.log
/var/log/lpr.log
/var/log/cron.log
/var/log/debug
/var/log/messages
considering log /var/log/mail.info
  log /var/log/mail.info does not exist -- skipping
considering log /var/log/mail.warn
  log /var/log/mail.warn does not exist -- skipping
considering log /var/log/mail.err
  log /var/log/mail.err does not exist -- skipping
considering log /var/log/mail.log
  log /var/log/mail.log does not exist -- skipping
considering log /var/log/daemon.log
considering log /var/log/kern.log
considering log /var/log/auth.log
considering log /var/log/user.log
considering log /var/log/lpr.log
  log /var/log/lpr.log does not exist -- skipping
considering log /var/log/cron.log
  log /var/log/cron.log does not exist -- skipping
considering log /var/log/debug
considering log /var/log/messages
rotating pattern: /var/log/ufw.log
considering log /var/log/ufw.log
  log does not need rotating (log has been rotated at 2020-5-29 0:0, that is not week ago yet)
rotating pattern: /var/log/wtmp  monthly (1 rotations)
olddir is /var/log.old, empty log files are rotated, only log files >= 1048576 bytes are rotated, log files >= 512000 are rotated earlier, old logs are removed
considering log /var/log/wtmp
  Last rotated at 2019-10-17 09:00
  log does not need rotating ('minsize' directive is used and the log size is smaller than the minsize value)
pi@emonpi:~$
As far as the version I am on, the Admin page says Version: low-write 10.1.13 for emonCMS. Here is the update log.
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
  master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
Changes not staged for commit:
  (use "git add ..." to update what will be committed)
  (use "git checkout -- ..." to discard changes in working directory)
	modified:   defaults/etc/logrotate.d/00_defaults
no changes added to commit (use "git add" and/or "git commit -a")
Already up to date.
Main Update Script
Date: Mon 25 May 22:22:28 CDT 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware:
Hardware detected: rfm2pi
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
nothing to commit, working tree clean
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git pull /opt/openenergymonitor/emonhub
* emon-pi
On branch emon-pi
Your branch is up to date with 'origin/emon-pi'.
From https://github.com/openenergymonitor/emonhub
 * [new branch]      MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
Already up to date.
Failed to restart .service.service: Unit .service.service not found.
- Service
Running emonhub automatic node addition script
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
 * branch              stable     -> FETCH_HEAD
error: Your local changes to the following files would be overwritten by merge:
	default-settings.php
	example.settings.ini
	example.settings.php
Please commit your changes or stash them before you merge.
Aborting
Updating 90f39158..8af639a9
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.1.1-42-ge5d51a4
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.9
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.0-29-g274bcd5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.2.2-6-g70894e1
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 1.2.4-5-gd689aae
- no local changes
From https://github.com/emoncms/demandshaper
   5865855..62acab6  master            -> origin/master
 * [new branch]      modular_forecasts -> origin/modular_forecasts
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.3-4-g5c50627
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.5
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- no local changes
Already up to date.
Already on 'stable'
Backup module installation and update script
- Loading EmonScripts config.ini
- Copying default.config.cfg to config.cfg
- Setting config.cfg settings
- Backup module symlink already exists
- PHP Version: 7.3
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- /var/opt/emoncms/backup already exists
- /var/opt/emoncms/backup/uploads already exists
- restarting apache
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
emonPi update done: Mon 25 May 22:23:12 CDT 2020
restarting service-runner
Regarding ufw and getting it to be less verbose. I took the suggestion to go to /etc/rsyslog.d/20-ufw.conf and remove the comment character before the &stop back when you suggested it. I have also added a specific “allow” rule for traffic coming from 192.168.1.80, my Dakboard node-red server that causes all the [BLOCK] entries in ufw.log. This hasn’t slowed down the logging a bit. I am suspicious that this is because the inbound hits from node-red all have different, seemingly random destination ports.
May 29 08:43:02 emonpi kernel: [39258.075608] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=54308 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:43:32 emonpi kernel: [39288.157728] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=53602 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:43:41 emonpi kernel: [39297.116653] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=54502 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:44:02 emonpi kernel: [39318.237702] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=54502 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:44:31 emonpi kernel: [39347.034810] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=53426 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:45:05 emonpi kernel: [39380.492002] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=54112 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:45:05 emonpi kernel: [39380.702926] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=54112 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:45:35 emonpi kernel: [39410.732790] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=55624 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:45:42 emonpi kernel: [39417.677312] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=55624 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:46:03 emonpi kernel: [39438.562653] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=55624 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:46:33 emonpi kernel: [39468.636009] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=55822 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:47:05 emonpi kernel: [39500.991027] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=55064 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:47:05 emonpi kernel: [39501.202692] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=55064 WINDOW=0 RES=0x00 RST URGP=0
May 29 08:47:35 emonpi kernel: [39531.122554] [UFW BLOCK] IN=eth0 OUT= MAC=b8:27:eb:3d:21:50:b8:27:eb:e2:7d:67:08:00:45:00:00:28:00:00:40:00:40:06:b7:07 SRC=192.168.1.80 DST=192.168.1.40 LEN=40 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=1880 DPT=51778 WINDOW=0 RES=0x00 RST URGP=0
You need to look in the logs and work out what is causing the excessive logging - it is the only way to fix it. I suggest you cast your query wider to Stackoverflow [edit] (or the Node-RED forum) for instance as this is not an emoncms issue.
I have also suggested using tshark on the Node-Red machine and see if you can work out what is sending the requests. Maybe try stopping some flows and see if that stops the requests.
The issue is you have ignored the comment at the top that says do not edit this file.
The changes you made to ‘default-settings.ini’ need to be moved to the settings.ini file.
Then the files should be reverted to their GitHub state.
I cannot remember the correct command. Do…
cd /var/www/emoncms
git pull
and the message will tell you what to do to delete your changes.
[edit]
It is the same problem with the first git pull that fails but that is because of the logrotate fix you used. You can revert that change as I’m sure Trystan said the fix had been merged.
git checkout -- <filename>
will revert your changes so the git pull works.
I admit I did find it confusing as to which settings file I needed to edit. In the end I did put my changes in settings.ini, but maybe I left behind some differences in the other files. The change I made to settings.ini was max_node_id_limit = 64
Just now I did this.
pi@emonpi:/var/www/emoncms$ git checkout -- default-settings.php
pi@emonpi:/var/www/emoncms$ git checkout -- example.settings.ini
pi@emonpi:/var/www/emoncms$ git checkout -- example.settings.php
pi@emonpi:/var/www/emoncms$ git pull
Fast-forward
 .travis.yml                                                    |    5 +
 Lib/EmonLogger.php                                             |   59 ++-
 Lib/dbschemasetup.php                                          |   76 ++-
 Lib/email.php                                                  |  100 ++--
 Lib/enum.php                                                   |   29 +-
 Lib/misc/nav_functions.php                                     |   11 +-
 Lib/misc/sidebar.css                                           |   50 +-
 Lib/misc/sidebar.js                                            |    7 +-
 Lib/process_old_settings.php                                   |    6 +-
 Lib/units.php                                                  |    6 +-
 Modules/admin/admin_controller.php                             |   43 +-
 Modules/admin/admin_db_view.php                                |   23 -
 Modules/admin/admin_main_view.php                              |   16 +-
 Modules/admin/admin_menu.php                                   |    2 +-
 Modules/admin/admin_model.php                                  |   74 +--
 Modules/admin/locale/it_IT/LC_MESSAGES/messages.mo             |  Bin 2392 -> 6742 bytes
 Modules/admin/locale/it_IT/LC_MESSAGES/messages.po             |  537 +++++++++++++++++---
 Modules/admin/locale/messages.pot                              |  462 +++++++++++++++++
 Modules/admin/pi-model.json                                    |  623 ++++++++++++-----------
 Modules/admin/static/admin_styles.css                          |   39 ++
 Modules/admin/userlist_view.php                                |    4 +-
 Modules/eventp/locale/eventp_messages.pot                      | 1138 +++++++++++++++++++++++++++++++++++++++++
 Modules/eventp/locale/it_IT/LC_MESSAGES/eventp_messages.mo     |  Bin 0 -> 999 bytes
 Modules/eventp/locale/it_IT/LC_MESSAGES/eventp_messages.po     | 1167 +++++++++++++++++++++++++++++++++++++++++++
 Modules/feed/Views/feedapi_view.php                            |    2 +-
 Modules/feed/Views/feedlist_view.php                           |   39 +-
 Modules/feed/engine/TemplateEngine.php                         |   67 ++-
 Modules/feed/engine/VirtualFeed.php                            |   46 +-
 Modules/feed/feed_controller.php                               |   48 +-
 Modules/feed/feed_model.php                                    |   33 +-
 Modules/feed/locale/it_IT/LC_MESSAGES/messages.mo              |  Bin 1827 -> 3995 bytes
 Modules/feed/locale/it_IT/LC_MESSAGES/messages.po              |  742 ++++++++++++++++++++++++---
 Modules/feed/locale/messages.pot                               |  631 +++++++++++++++++++++++
 Modules/input/Views/input_api.php                              |    2 +-
 Modules/input/Views/input_view.js                              |   31 +-
 Modules/input/Views/input_view.php                             |   25 +-
 Modules/input/Views/schedule.php                               |    8 +-
 Modules/input/input_controller.php                             |    3 +-
 Modules/input/input_menu.php                                   |   10 +-
 Modules/input/input_methods.php                                |    1 +
 Modules/input/input_model.php                                  |    6 +-
 Modules/input/locale/it_IT/LC_MESSAGES/messages.mo             |  Bin 1153 -> 4010 bytes
 Modules/input/locale/it_IT/LC_MESSAGES/messages.po             |  777 +++++++++++++++++++---------
 Modules/input/locale/messages.pot                              |  543 ++++++++++++++++++++
 Modules/process/Views/process_ui.js                            |   14 +-
 Modules/process/Views/process_ui.php                           |    9 +-
 Modules/process/locale/it_IT/LC_MESSAGES/process_messages.mo   |  Bin 0 -> 6119 bytes
 Modules/process/locale/it_IT/LC_MESSAGES/process_messages.po   | 1166 ++++++++++++++++++++++++++++++++++++++++++
 Modules/process/locale/process_messages.pot                    |  922 ++++++++++++++++++++++++++++++++++
 Modules/process/process_model.php                              |   32 +-
 Modules/process/process_processlist.php                        |   80 ++-
 Modules/schedule/locale/it_IT/LC_MESSAGES/schedule_messages.mo |  Bin 0 -> 2817 bytes
 Modules/schedule/locale/it_IT/LC_MESSAGES/schedule_messages.po |  317 ++++++++++++
 Modules/schedule/locale/schedule_messages.pot                  |  261 ++++++++++
 Modules/user/locale/it_IT/LC_MESSAGES/messages.mo              |  Bin 4776 -> 7188 bytes
 Modules/user/locale/it_IT/LC_MESSAGES/messages.po              |  387 ++++++++------
 Modules/user/locale/messages.pot                               |  361 +++++++++++++
 Modules/user/rememberme_model.php                              |    4 +-
 Modules/user/user_controller.php                               |    4 +-
 Modules/user/user_menu.php                                     |    5 +-
 Modules/user/user_model.php                                    |   31 +-
 Modules/vis/README.md                                          |   38 ++
 Modules/vis/locale/it_IT/LC_MESSAGES/vis_messages.mo           |  Bin 4865 -> 8493 bytes
 Modules/vis/locale/it_IT/LC_MESSAGES/vis_messages.po           | 1051 +++++++++++++++++++++++++++++---------
 Modules/vis/locale/vis_messages.pot                            |  941 ++++++++++++++++++++++++++++++++++
 Modules/vis/vis_object.php                                     |   40 +-
 Modules/vis/visualisations/editrealtime.php                    |   58 ++-
 Modules/vis/visualisations/multigraph.php                      |   86 ++--
 Modules/vis/visualisations/multigraph/multigraph.js            |  290 ++++++-----
 Modules/vis/visualisations/rawdata.php                         |    1 +
 Modules/vis/visualisations/realtime.php                        |    2 +-
 Modules/vis/visualisations/stacked.php                         |    9 +-
 Modules/vis/visualisations/stackedsolar.php                    |    9 +-
 Theme/basic/embed.php                                          |    9 +-
 Theme/basic/emon-blue.css                                      |    4 +-
 Theme/basic/emon-standard.css                                  |    4 +-
 Theme/basic/emon-sun.css                                       |    4 +-
 Theme/basic/locale/it_IT/LC_MESSAGES/theme_messages.mo         |  Bin 0 -> 983 bytes
 Theme/basic/locale/it_IT/LC_MESSAGES/theme_messages.po         |   54 ++
 Theme/basic/locale/theme_messages.pot                          |   54 ++
 Theme/basic/menu_view.php                                      |    7 +-
 Theme/basic/sidebar_view.php                                   |    3 -
 Theme/basic/theme.php                                          |    5 +-
 composer.json                                                  |   12 +-
 core.php                                                       |  215 +++++---
 default-settings.ini                                           |   12 +-
 default-settings.php                                           |   14 +-
 docs/RaspberryPi/language_support.md                           |   49 ++
 example.settings.ini                                           |   14 +-
 example.settings.php                                           |    8 +-
 index.php                                                      |  704 +++++++++++++-------------
 locale.php                                                     |   31 +-
 param.php                                                      |   79 ++-
 php-info.php                                                   |    2 +-
 process_settings.php                                           |   87 ++--
 readme.md                                                      |   41 +-
 route.php                                                      |    8 +-
 scripts/phpmqtt_input.php                                      |   18 +-
 scripts/services/emoncms_mqtt/emoncms_mqtt.php                 |  110 ++--
 settings.env.ini                                               |   27 +-
 version.txt                                                    |    2 +-
 101 files changed, 12911 insertions(+), 2275 deletions(-)
 delete mode 100644 Modules/admin/admin_db_view.php
 create mode 100644 Modules/admin/locale/messages.pot
 create mode 100644 Modules/eventp/locale/eventp_messages.pot
 create mode 100644 Modules/eventp/locale/it_IT/LC_MESSAGES/eventp_messages.mo
 create mode 100644 Modules/eventp/locale/it_IT/LC_MESSAGES/eventp_messages.po
 create mode 100644 Modules/feed/locale/messages.pot
 create mode 100644 Modules/input/locale/messages.pot
 create mode 100644 Modules/process/locale/it_IT/LC_MESSAGES/process_messages.mo
 create mode 100644 Modules/process/locale/it_IT/LC_MESSAGES/process_messages.po
 create mode 100644 Modules/process/locale/process_messages.pot
 create mode 100644 Modules/schedule/locale/it_IT/LC_MESSAGES/schedule_messages.mo
 create mode 100644 Modules/schedule/locale/it_IT/LC_MESSAGES/schedule_messages.po
 create mode 100644 Modules/schedule/locale/schedule_messages.pot
 create mode 100644 Modules/user/locale/messages.pot
 create mode 100644 Modules/vis/README.md
 create mode 100644 Modules/vis/locale/vis_messages.pot
 create mode 100644 Theme/basic/locale/it_IT/LC_MESSAGES/theme_messages.mo
 create mode 100644 Theme/basic/locale/it_IT/LC_MESSAGES/theme_messages.po
 create mode 100644 Theme/basic/locale/theme_messages.pot
 create mode 100644 docs/RaspberryPi/language_support.md
Yep that worked.
Me again. /var/log is full again despite turning off ufw and certbot (I moved this setup to another machine). Any suggestions on what to do next?
pi@emonpi:/etc/apache2/sites-enabled$ df -h
/dev/root       4.0G  2.7G  1.1G  72% /
tmpfs           464M   47M  417M  11% /run
tmpfs            30M  4.0K   30M   1% /tmp
pi@emonpi:/etc/apache2/sites-enabled$ ls -lh --size /var/log
total 536K
   0 -rw-r--r-- 1 root      root       0 Dec  1  2019 alternatives.log
   0 drwxr-xr-x 2 root      root     100 Dec  1  2019 apt
 40K -rw-r----- 1 root      adm      40K Jun 10 12:40 auth.log
   0 -rw-rw---- 1 root      utmp       0 Jun  3 15:17 btmp
 28K -rw-r----- 1 root      adm      28K Jun 10 12:39 daemon.log
   0 -rw-r----- 1 root      adm        0 Jun  3 15:17 debug
   0 -rw-r--r-- 1 root      root       0 Dec  1  2019 dpkg.log
   0 drwxr-xr-x 2 pi        root     160 Jun  9 16:17 emoncms
   0 -rw-r----- 1 root      adm        0 Jun  8 22:10 kern.log
288K -rw-rw-r-- 1 root      utmp    286K Jun  9 14:43 lastlog
   0 drwx------ 2 root      root      60 Jun  7 00:17 letsencrypt
   0 -rw-r--r-- 1 root      root       0 Jun  4 01:17 log2ram.log
   0 drwxr-xr-x 2 root      adm      220 Jun 10 12:17 logrotate
4.0K -rw-r----- 1 root      adm     4.0K Jun 10 12:40 messages
   0 drwxr-s--- 2 mysql     adm       60 Jun 10 00:17 mysql
   0 drwxr-s--- 2 redis     adm       60 Jun  3 15:17 redis
 12K -rw-r----- 1 root      adm      12K Jun 10 12:40 syslog
 24K -rw-r----- 1 root      adm      24K Jun  9 15:19 ufw.log
   0 -rw-r----- 1 root      adm        0 Jun  3 15:17 user.log
4.0K -rw-r--r-- 1 root      root    1.1K Jun  3 14:18 wifiAP.log
112K -rw-rw-r-- 1 root      utmp    112K Jun  9 14:43 wtmp
pi@emonpi:/etc/apache2/sites-enabled$ sudo find /var/log -type f -exec du -ah {} + | sort -n -r | head -n 20
112K	/var/log/wtmp
96K	/var/log/logrotate/logrotate.log
40K	/var/log/auth.log
28K	/var/log/daemon.log
24K	/var/log/ufw.log
12K	/var/log/syslog
8.0K	/var/log/logrotate/logrotate.log.4.gz
8.0K	/var/log/logrotate/logrotate.log.3.gz
4.0K	/var/log/mosquitto/mosquitto.log
4.0K	/var/log/messages
4.0K	/var/log/logrotate/logrotate.status
4.0K	/var/log/logrotate/logrotate.log.6.gz
For those that might benefit, here’s what I’ve learned in the last couple weeks.
  1. If you are going to run a reverse proxy on a Raspberry Pi within your network, don’t use the same Pi that you are using for emonCMS. Every time you need to restart apache2 to update your proxy settings, emonCMS is effected. And all the logging that you want from your proxy server is more logging than you might want on your emonCMS server. At least this is my opinion after what I’ve been doing lately.
  2. Cloudflare proxy makes a lot of sense, and Paul Reed has a nice write-up on how to set it up with ufw to limit traffic into your network to only that which has come through Cloudflare, including a script that keeps ufw up-to-date with Cloudflare’s current IP addresses.
So I now have a separate reverse proxy Pi inside my network that is looking for valid traffic from Cloudflare and proxying it to emonCMS.
I like this setup better, and I hoped it would resolve the full /var/log problem, but apparently not.
Those numbers do not seem to add up to 50M which is the size of /var/log
