All inputs stopped logging this morning?!
OK I set to debug, saved, restarted emonhub, rebooted. Please see attached the compressed syslog and the emonhub.conf extract
syslog.zip (52.3 KB)
#######################      emonhub.conf     #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
#######################    emonHub  settings    #######################
[hub]
### loglevel must be one of INFO, INFO, WARNING, ERROR, and CRITICAL
loglevel = DEBUG
use_syslog = yes
[interfacers]
###[[RFM2Pi]]
###    Type = EmonHubJeeInterfacer
###    [[[init_settings]]]
###        com_port = /dev/ttyAMA0
###        com_baud = 38400                        # 9600 for old RFM12Pi
###    [[[runtimesettings]]]
###        pubchannels = ToEmonCMS,
###        subchannels = ToRFM12,
###        group = 210
###        frequency = 433
###        baseid = 5                              # emonPi / emonBase nodeID
###        calibration = 230V                      # (UK/EU: 230V, US: 110V)
###        quiet = true                            # Disable quite mode (default enabled) to enable RF packet debugging, show packets which fail crc
###        # interval =  300                         # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
    Type = EmonHubMqttInterfacer
    [[[init_settings]]]
        mqtt_host = 127.0.0.1
        mqtt_port = 1883
        mqtt_user = emonpi
        mqtt_passwd = emonpimqtt2016
        pubchannels = ToRFM12,
        subchannels = ToEmonCMS,
        # emonhub/rx/10/values format
        node_format_enable = 1
        nodevar_format_enable = 1
[[emoncmsorg]]
    [[[init_settings]]]
        url = https://emoncms.org
        apikey = ac72875d3009501a****************
        senddata = 1                    # Enable sending data to Emoncms.org
        sendstatus = 1                  # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
        sendinterval= 30                # Bulk send interval to Emoncms.org in seconds
#######################          Nodes          #######################
[Edit: APIkey obscured - (Moderator (RW) ]
Thanks @tommyt why did you comment out the RFM2Pi interfacer? That would explain it if you are expecting to see data from the emonPi?
Could be my fault, Sorry :frowning:
Well, weird thing, I just put it back in, and the feeds sprang into life! Doesn’t make any sense, as the overall config is unchanged from earlier today.
@TrystanLea @borpin Thanks for your help. No idea why it happened in the first place or indeed what caused it to rectify in the end! I do wonder what those authentication error messages in the log were all about though
