Hi Guys,
I have a few Mi Temp sensors setup with Zigbee2mqtt gateway and home assistant.
I’d like to send their values to an Emoncms feed.
Reading through blog posts, articles and documentation I haven’t found a clear answer.
How would you accomplish this ?
borpin
(Brian Orpin)
#2
I do this in my configuration.yaml
mqtt_statestream:
base_topic: emon
include:
entities:
- sensor.mi_h_4c65a8d8de98
You will then see this appear under a Node called sensor.
Occasionally I get a zero at startup of HA so worth ignoring it in the input processing.
HTH
Thank you! This is so awesome !
