I am starting my testing on the current monitor (will be incorporating a voltage sensor in the final build though). I will be using mostly the YHDC AC Current Sensor - 30A sensors (individual circuits, but the 100 amp variant for total usage) and noted the spec’s state 30A/1V as appose to 100A/50mA. So following this: guide I do not need the burden resistor, but still will use 2x10k resistors and the cap?
Cassie v Eck
