Wi-Fi schematic
Is their a schematic for this Wi-Fi board, I’ve not been able to find one anywhere?
The Qwik port is I2C ( check for Qwik i2c pinout)
The other ones are the same as V1 module, i.e led port and serial.
You also have a 16mb flash on this board.
Thank you, yes I knew all that but I am looking for a schematic. I can’t find one for the V1 either, as I realised the only difference looks to be the qwiic and ic.
this ? GitHub - OpenEVSE/ESP32_hardware: OpenEVSE network communications controllers based on the ESP32 Module.
Thank you, I couldn’t find it. :frowning:
Sorted.
