Both are actually NodeID=8
7 + 1 = 8
8 + 0 = 8
You thought you had one Node 8 and the other was not working - you actually had both reporting as Node 8. You might have seen the values reported varying because it would show the value for one, then the other.
If you turn off the DIP switch for the one with int nodeID = 7, then that one will appear as Node 7. There is no need to edit and reload the sketch, but you must press the reset button after you have changed the switch, because it only looks at the switch as the sketch starts.
