# Web Based Backup Fails
**URL:** <https://community.openenergymonitor.org/t/web-based-backup-fails/9541>\
**Category:** emonPi\
**Created:** [20 December 2018 07:57 UTC](https://community.openenergymonitor.org/t/web-based-backup-fails/9541 "2018-12-20T07:57:18Z")\
**Showing post:** 13
**Author:** ![andrewhf01](https://community.openenergymonitor.org/letter_avatar_proxy/v4/letter/a/858c86/32.png) [@andrewhf01](https://community.openenergymonitor.org/u/andrewhf01)\
**Post date:** [6 June 2019 20:45 UTC](https://community.openenergymonitor.org/t/web-based-backup-fails/9541/13 "2019-06-06T20:45:14Z")
Hi Jon,
Thanks for the info, I’ll try CyberDuck to transfer files at some point in the very near future.
At present I’m imaging the old SD card before I do anything else then I’m going to try accessing the drive with these backup files directly (I have Paragon extFS) then I can try uploading my old Emoncms data to the new installed emonpi, which I’m having issues with connecting via wifi as per [WiFi connection issues](https://community.openenergymonitor.org/t/wifi-connection-issues/9453)
So, I’m using the wired ethernet connection and will try and fix each of the issues and glitches throughout this upgrade to get it functioning the same, prior to the system crash at the beginning of last month that necessitated the the overhaul.
Not played with this kit for some while therefore, need to refamiliarise myself and improve my knowledge as well.
Many thanks
Andrew
_[View the full topic](https://community.openenergymonitor.org/t/web-based-backup-fails/9541)._
