I have a question, in the repo “diyBMSv4” branch “v4.6” you integrated a ve.direct interface at the beginning of the year and then removed it again. I find the topic very exciting, did you plan to operate a Victron shunt on the ESP32-BOARD?
I did think about adding in a ve.direct interface to DIYBMS - but then quickly removed it!
This was purely for the idea of using the Victron smartshunt as an input into DIYBMS controller - however, given that it can use bluetooth - and so can the ESP32, that might be a better way to go.
Ultimately - I decided to pull it, and go down another route.
