V4.4 cell module issue
Maybe someone can help me out with this one. Running the v4.4 cell modules and using a Wemo mini d for the controller. Issue is one of the cell modules does not track voltage nor does it show temperature. I have not separated the temp module from the board. Thought maybe it was just a bad cell module so soldered up another one and it had the same issues.
I”m able to set the calibration voltage and it saves it but the voltage never changes after that regardless of charge or discharge of cell. Any thoughts on what to check or where on the board?
