Or if you were on the TestFlight builds from a couple of years ago you should get access soon. If you’re not on TestFlight builds and want to be, then let me know and I can add you. Alternatively, just wait until it’s out in the App Store which will be in the coming week or so!
Apple approves the TestFlight build. So if you’re on the list - go get it! Especially I’m interested in if the settings from the original app migrate properly. I’ve tested it a lot but I’m really cautious about that. I significantly changed the data model so things can go wrong.
Version with that coming to TestFlight later today :-). Version in TestFlight now.
This is going to be super useful for me personally because I often want to quickly check on the temperature of the water in my tank. So I am able to swipe left on my home screen and instantly see it now.
Hi @mattjgalloway, many thanks for the major update and the amazing new features. I just tested the current beta version 1.1 (18). Dashboards and inputs are unfortunately not displayed, what could be the reason? I am using the current emoncms stable version, Dashboard is on master and input is on stable.
One thing I noticed: is it intentional that the API readkey is not shown when editing the account settings? This irritated me a bit, so I re-entered the key because I thought it had been deleted.
For both of these they require an update to emoncms. The code for inputs is committed, the code for dashboards is waiting review. And then for both they’ll need to make it to stable branch. I will make sure that these things happen before we submit to the App Store. For now - you can update to use master, and for the dashboards, apply my PR.
Yes - it was. If you don’t enter anything then it saves without the key changing. I certainly could make that more obvious though :-). I shall do that.
Thanks for testing!! Anything you find - please let me know.
I’ve just pulled the change in so as long as you are running the latest versions of emoncms and the dashboard module (master branches), you should be good.
Unfortunately that’s not possible as Apple require using https. There is an exception I have in there for specific domains, currently “emonpi”, “.local” and “.home”. So if your emonpi is on one of those you can use http.
