admin → users → click on id
gives “406 Not Acceptable. Route not found”
what am i missing now ?
i am folowing a old instalation guide maybe ?
rob1
(rob)
31 May 2019 14:56
2
I can’t help you, but I can confirm my upgraded installation does the same…
{“success”:false,“message”:“406 Not Acceptable. Route not found”}
borpin
(Brian Orpin)
1 June 2019 09:32
3
Seems it is a bug. I have raised an issue.
opened 09:32AM - 01 Jun 19 UTC
closed 11:13AM - 05 Jun 19 UTC
admin -> users -> click on id
Gives “406 Not Acceptable. Route not found”
… <details><summary>Server Information</summary>
# Server Information
## Services
- **emonhub** :- **Active** Running
- **emoncms_mqtt** :- **Active** Running
- **feedwriter** :- **Active** Running - sleep 60s 10 feed points pending write
- **service-runner** :- **Active** Running
- **emonPiLCD** :- **Active** Running
- **redis-server** :- **Active** Running
- **mosquitto** :- **Active** Running
## Emoncms
- **Version** :- low-write 10.0.2
- **Modules** :- Administration | App v2.0.1 | Backup v2.0.0 | EmonHub Config v2.0.2 | Dashboard v2.0.1 | Device v2.0.0 | EventProcesses | Feed | Graph v2.0.1 | Input | Postprocess v2.0.0 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.0
- **Git** :-
- **URL** :- https://github.com/emoncms/emoncms.git
- **Branch** :- * stable
- **Describe** :- 10.0.2-4-g9e7c6804
## Server
- **OS** :- Linux 4.14.71-v7+
- **Host** :- emonpi | emonpi | (192.168.7.243)
- **Date** :- 2019-06-01 10:30:45 BST
- **Uptime** :- 10:30:45 up 4 days, 20:05, 1 user, load average: 0.14, 0.10, 0.09
## Memory
- **RAM** :- Used: 17.77%
- **Total** :- 976.74 MB
- **Used** :- 173.61 MB
- **Free** :- 803.13 MB
- **Swap** :- Used: 0.00%
- **Total** :- 100 MB
- **Used** :- 0 B
- **Free** :- 100 MB
## Disk
- **/** :- Used: 40.34%
- **Total** :- 3.81 GB
- **Used** :- 1.54 GB
- **Free** :- 2.1 GB
- **/boot** :- Used: 51.69%
- **Total** :- 42.52 MB
- **Used** :- 21.98 MB
- **Free** :- 20.54 MB
- **/home/pi/data** :- Used: 5.50%
- **Total** :- 3.21 GB
- **Used** :- 180.78 MB
- **Free** :- 2.87 GB
## HTTP
- **Server** :- Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
## MySQL
- **Version** :- 5.5.5-10.1.23-MariaDB-9+deb9u1
- **Host** :- localhost:6379 (127.0.0.1)
- **Date** :- 2019-06-01 10:30:45 (UTC 01:00)
- **Stats** :- Uptime: 417935 Threads: 2 Questions: 32382 Slow queries: 0 Opens: 24 Flush tables: 1 Open tables: 18 Queries per second avg: 0.077
## Redis
- **Version** :- 3.2.6
- **Size** :- 106 keys (782.26K)
- **Uptime** :- 4 days
## MQTT Server
- **Version** :- Mosquitto 1.4.10
- **Host** :- localhost:1883 (127.0.0.1)
## PHP
- **Version** :- 7.0.30-0+deb9u1 (Zend Version 3.0.0)
- **Modules** :- apache2handler | calendar v7.0.30-0+deb9u1 | Core v7.0.30-0+deb9u1 | ctype v7.0.30-0+deb9u1 | curl v7.0.30-0+deb9u1 | date v7.0.30-0+deb9u1 | dom v20031129 | exif v7.0.30-0+deb9u1 | fileinfo v1.0.5 | filter v7.0.30-0+deb9u1 | ftp v7.0.30-0+deb9u1 | gd v7.0.30-0+deb9u1 | gettext v7.0.30-0+deb9u1 | hash v1.0 | iconv v7.0.30-0+deb9u1 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.30-0+deb9u1 | mbstring v7.0.30-0+deb9u1 | mcrypt v7.0.30-0+deb9u1 | mosquitto v0.4.0 | mysqli v7.0.30-0+deb9u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ | openssl v7.0.30-0+deb9u1 | pcre v7.0.30-0+deb9u1 | PDO v7.0.30-0+deb9u1 | pdo_mysql v7.0.30-0+deb9u1 | Phar v2.0.2 | posix v7.0.30-0+deb9u1 | readline v7.0.30-0+deb9u1 | redis v4.1.1 | Reflection v7.0.30-0+deb9u1 | session v7.0.30-0+deb9u1 | shmop v7.0.30-0+deb9u1 | SimpleXML v7.0.30-0+deb9u1 | sockets v7.0.30-0+deb9u1 | SPL v7.0.30-0+deb9u1 | standard v7.0.30-0+deb9u1 | sysvmsg v7.0.30-0+deb9u1 | sysvsem v7.0.30-0+deb9u1 | sysvshm v7.0.30-0+deb9u1 | tokenizer v7.0.30-0+deb9u1 | wddx v7.0.30-0+deb9u1 | xml v7.0.30-0+deb9u1 | xmlreader v7.0.30-0+deb9u1 | xmlwriter v7.0.30-0+deb9u1 | xsl v7.0.30-0+deb9u1 | Zend OPcache v7.0.30-0+deb9u1 | zlib v7.0.30-0+deb9u1
## Pi
- **Model** :- Raspberry Pi 3 Model B+ Rev 1.3 - 1 GB (Sony UK)
- **SoC** :- Broadcom BCM2835
- **Serial num.** :- 71604C19
- **Temperature** :- 49.39°C - 49.4°C
- **emonpiRelease** :- emonSD-30Oct18
- **File-system** :- read-write
</details>
<details><summary>Client Information</summary>
# Client Information
## HTTP
- **Browser** :- Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.88 Safari/537.36 Vivaldi/2.4.1488.36
- **Language** :- en-US,en;q=0.9
## Window
- **Size** :- 1414 x 833
## Screen
- **Resolution** :- 1920 x 1080
</details>
Yup my installation is the same way after upgrading.
borpin
(Brian Orpin)
5 June 2019 19:16
6
If you stay on the stable branch it will not change until the next release. @glyn.hudson @TrystanLea any plans for a patch release before the major updates?
I’d just be happy with a manual patch, that would be overwritten with the next release.
borpin
(Brian Orpin)
6 June 2019 04:37
8
You can switch to master branch. This is what was done on this thread. The process is exactly the same for you to pick up the latest dev version.
This fix has been merged into Master branch.
@jonharnew If you are happy to switch branches and pull in the latest changes from maser branch could you confirm issue has been fixed for you:
Please ensure you run a full EmonCMS update from the admin page before running these commands
cd /var/www/emoncms
git pull
git checkout master
git pull origin master
By update, do you mean an apt update? or an internal update script?
borpin
(Brian Orpin)
6 June 2019 11:57
10
The link I provided goes to some instructions to switch branch in git for the EmonCMS code.
Further down the thread are some instructions on using SSH if you need them.
[edit] I just realised you may have meant the use of ‘update’ in that link. I have amended the comment to clarify I mean a full update from the EmonCMS admin page.
