As well as EMON CMS I have a Desktop server running home assistant that generates me some stats.
I am looking to integrate in the data from the heat pump into this
I get daily reports in the following format - example
I am looking to create the following but need to get these entities into my home assistant to do this and create the results in a table format like above
Ideally would like to see following broken down by live view, every 30 mins on the hour and 30 mins past the hour, daily, monthly.
PV generated kWh
Battery / in and out kWh
Grid / in and out kWh
Heat Pump Consumption kWh Hot Water
Heat Pump Generated kWh Hot Water
Immersion Eddi Consumption kWh
Hot Water COP
Heat Pump Consumption kWh Radiators house heating
Heat Pump Generated kWh Radiator house heating
Space Heating COP
Outside Temperature Celcius
Other Electric Consumption kWh
Total Electric Consumption House Load kWh
Not really sure how I go about getting the EmonCMS data into my other server to show this, can anyone help me?
Logger: homeassistant.components.sensor
Source: components/sensor/init.py:570
integration: Sensor (documentation, issues)
First occurred: 26 May 2024 at 10:20:49 (2 occurrences)
Last logged: 26 May 2024 at 10:20:49
Entity sensor.energy_hp_in_today (<class ‘homeassistant.components.utility_meter.sensor.UtilityMeterSensor’>) is using state class ‘total_increasing’ which is impossible considering device class (‘power’) it is using; expected None or one of ‘measurement’; Please update your configuration if your entity is manually configured, otherwise create a bug report at Issues · home-assistant/core · GitHub
Entity sensor.energy_hp_out_today (<class ‘homeassistant.components.utility_meter.sensor.UtilityMeterSensor’>) is using state class ‘total_increasing’ which is impossible considering device class (‘power’) it is using; expected None or one of ‘measurement’; Please update your configuration if your entity is manually configured, otherwise create a bug report at Issues · home-assistant/core · GitHub
