Hi, our power got cut and on reboot the Emonpi has Updating… do not unplug on the LCD. Been like that for a hour… how long do updates take? Maybe a corrupt card due the power cut? If so what do I do? Any help appreciated
Welcome.
Can you SSH in?
Thanks for the reply Brian, ended up on that screen for 2 hours… decided it must be frozen or SD corrupt, wouldn’t reset so master reset… pulled the plug… booted up ok, back to updating for a few minutes and then all good, logging sweet data again! Big learning curve
It is worth at least having a surge protector in place. Power cuts are not usually a problem, but they can be accompanied by power surges which can be fatal.
Was it logging data during that time?
Yes, was logging inputs froze. Good idea about the surge protector
If it was logging, what do you mean by ‘inputs froze’? Do you mean the LCD? There is a suspicion it is something within the boot that causes that - never been found.
It was logging to tablet, the power at the time continued or froze, so 1300w constant for a couple of hours
