Hi Glyn
Thanks for help with the startup of emonPi.
Now I’m running with the latest software, and it looks something different and better.
However, I have wondered about the VRMS value is well above the actual voltage (260.6V) against the measured value: 232 V. Is it normal that it should be adjusted via emonhub?
[[8]]
node name = emontx3
[[[Rx]]]
names = Power1, POWER2, Power3, POWER4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
datacodes = h, h, h, h, h, h, h, h, h, h, h, L
units = W, W, W, W, V, C, C, C, C, C, C, P
I read somewhere on the forums that an update to the latest firmware version solved the problem of error vrms display, but it does not seem to be the case.
Can there be a need to update the firmware in emontx3 ?
Best wishes
Sune
