This is the output from a brand new Arduino Uno R3 with Tx Shield, fresh install of the 3phase firmware version1.0, from master, no changes except making the line #define EMONTX_SHIELD.
As you know, simply entering config mode ‘+++’ and pressing ‘r’ (with NL & CR set next to Baud rate in Arduino IDE) will make use of the sketch default values and provide basic functionality.
I wouldn’t define this as ‘out of the box’ functionality. Particularly with the incorrect iCal values defaulted for the TxShield.
That is all :slight_smile:
