Hello,
I request some feed data from Emoncms using the following API url : [https://emoncms.org/feed/data.json?id=0&start=UNIXTIME_MILLISECONDS&end=UNIXTIME_MILLISECONDS&interval=10] (example of the documentation).
But there is no specified unit for the returned values in the documentation located in [Emoncms - site api] (“Returns feed data between start time and end time at the interval specified. If no data is present null values are returned.”)
The unit is not specified in the response data either.
For some similar requests the API documentation specify that the returned values are in kWh but it seems unrealistic for my request considering the returned values.
If anyone has an idea on the unit or on the way to have it would be really helpful.
Thank you for your help
