overeasy
(Inactive)
14
I tried using a negated grid value for “import_kwh” but it doesn’t change anything. So the negative grid is how it is. Here’s a shot of the app while the system is exporting. As in th My Solar app, the real-time red importing
becomes green exporting
But the “Grid” box below remains red either way.
I was also mystified by the value in the black space between solar and grid. I have determined that is the actual Kwh exported to the grid. With the solar diverter, you would expect that to be a low number. Here in this example without a diverter (using the heat-pump water heater load to simulate), there is some export.
And as you can see from this My Solar from the same period, the 3.8 is Kwh exported, and the -4.6 is the
net Kwh exported (4.6 imported). Makes my head hurt, but if you are going to put the numbers side by side, it does kind of make some sense to make one positive if it represents export, and the other negative if it represents a net export. I suppose you could do the opposite, but there is a certain logic to it.
