Hi, I have a standard (emonpi/emontx/emonth and CTs etc) set-up bought in Feb 2019 and installed as per the on-line guides with no software changes (I am not confident enough to meddle!) and all working perfectly. It’s a brilliant system and thanks to all who have developed and contributed to it.
A couple of months ago I did a “full Update” on the Admin page which I am pretty sure worked fine and my emoncms version became low-write 10.1.13.
I noticed recently that the latest stable version of emoncms is 10.1.19 so tried doing firstly a emoncms-only update, and then a Full Update from the Admin page. As far as I can tell from the update log there didn’t seem to be any issues, but my emoncms version appears to have stayed at 10.1.13.
Have I interpreted this correctly please? If so, should I update to 10.1.19, and how do I do it please?
Below I have copied my latest Update Log and the Server Information. Thank you
PS - I have logged out and back in after each attempt as well.
Starting update via service-runner-update.sh (v2.0) >
- emonSD version: emonSD-30Oct18
emonSD base image check passed...continue update
git pull /home/pi/emonpi
enable-ssh
enable-ssh-button
gpiozero-enable-ssh
greeebs-patch-1
* master
python-systemd-servicerunner
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
Already up-to-date.
Main Update Script
Date: Fri 3 Jan 18:26:34 UTC 2020
EUID: 1000
usrdir: /home/pi
type: all
firmware: none
Checking environment:
- pi user found
EUID: 1000
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD DETECTED Ox27
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Fetched 40.3 kB in 1s (29.0 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
rng-tools is already the newest version (2-unofficial-mt.14-1).
python-gpiozero is already the newest version (1.5.0).
python-rpi.gpio is already the newest version (0.6.5~stretch-1).
0 upgraded, 0 newly installed, 0 to remove and 149 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
git pull /home/pi/RFM2Pi
* master
On branch master
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
* emon-pi
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
Already up-to-date.
Creating emonhub logfile
Symlinking emonhub.conf to /etc/emonhub/emonhub.conf
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- emoncms directory: /var/www/emoncms
current settings.php md5: 59e80f731935867f5f93753d49c0fe86
Default settings.php md5: 59e80f731935867f5f93753d49c0fe86
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
Fetching origin
- git branch: stable
- no local changes
- running: git pull origin stable
Branch stable set up to track remote branch stable from origin.
Already up-to-date.
NEW default settings.php md5: 59e80f731935867f5f93753d49c0fe86
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
Fetching origin
- git tags: 2.0.1-82-g48fb43b
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/config module
Fetching origin
- git tags: 2.0.2-9-g1bba25a
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/dashboard module
Fetching origin
- git tags: 2.0.3-41-g3c20c5b
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/device module
Fetching origin
- git tags: 2.0.0-22-g46654e9
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/graph module
Fetching origin
- git tags: 2.0.1-63-g4ca7cf9
- no local changes
Already up-to-date.
Updating /var/www/emoncms/Modules/wifi module
Fetching origin
- git tags: 2.0.0-29-g274bcd5
- no local changes
Already up-to-date.
Updating postprocess module
Fetching origin
- git tags: 2.1.0-20-ga9b1516
- no local changes
Already up-to-date.
Updating sync module
Fetching origin
- git tags: 2.0.1-15-g39361e4
- no local changes
Already up-to-date.
Updating backup module
Fetching origin
- git tags: 2.0.0-39-g81b5912
- no local changes
Already up-to-date.
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
/home/pi/emonpi/sudoers.d/emoncms-rebootbutton: parsed OK
emoncms-rebootbutton sudoers entry installed
/home/pi/emonpi/sudoers.d/emoncms-filesystem: parsed OK
emoncms-filesystem sudoers entry installed
/home/pi/emonpi/sudoers.d/wifi-sudoers: parsed OK
wifi-sudoers sudoers entry installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
Symlinking emonpiupdate.log
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
Emoncms update script complete
Starting emonPi LCD service..
emonPi update done: Fri 3 Jan 18:28:13 UTC 2020
restarting service-runner
service-runner: no process found
Server Information
Services
emonhub : Active Running
emoncms_mqtt : Active Running
feedwriter : Active Running - sleep 60s 79 feed points pending write
service-runner : Active Running
emonPiLCD : Active Running
redis-server : Active Running
mosquitto : Active Running
Emoncms
Version : low-write 10.1.13
Modules : Administration | App v2.0.9 | Backup v2.1.7 | EmonHub Config v2.0.4 | Dashboard v2.0.5 | Device v2.0.3 | EventProcesses | Feed | Graph v2.0.7 | Input | Postprocess v2.1.2 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.2
Git :
URL : https://github.com/emoncms/emoncms.git
Branch : * stable
Describe : 10.1.11-7-g90f39158
Server
OS : Linux 4.14.71-v7+
Host : emonpi | emonpi | (192.168.1.67)
Date : 2020-01-03 18:31:21 UTC
Uptime : 18:31:21 up 7:08, 0 users, load average: 0.32, 0.51, 0.36
Memory
RAM : Used: 17.14%
Total : 976.74 MB
Used : 167.44 MB
Free : 809.3 MB
Swap : Used: 0.00%
Total : 100 MB
Used : 0 B
Free : 100 MB
Write Load Period
Disk
/ : Used: 40.40%
Total : 3.81 GB
Used : 1.54 GB
Free : 2.09 GB
Write Load : 2.14 KB/s (7 hours 7 mins)
/boot : Used: 51.69%
Total : 42.52 MB
Used : 21.98 MB
Free : 20.54 MB
Write Load : 0 B/s (7 hours 7 mins)
/home/pi/data : Used: 3.37%
Total : 10.32 GB
Used : 355.67 MB
Free : 9.44 GB
Write Load : 1.6 KB/s (7 hours 7 mins)
HTTP
Server : Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version : 5.5.5-10.1.23-MariaDB-9+deb9u1
Host : localhost:6379 (127.0.0.1)
Date : 2020-01-03 18:31:21 (UTC 00:00)
Stats : Uptime: 25727 Threads: 3 Questions: 2574 Slow queries: 0 Opens: 30 Flush tables: 1 Open tables: 24 Queries per second avg: 0.100
Redis
Version :
Redis Server : 3.2.6
PHP Redis : 4.1.1
Size : 515 keys (826.00K)
Uptime : 0 days
MQTT Server
Version : Mosquitto 1.4.10
Host : localhost:1883 (127.0.0.1)
PHP
Version : 7.0.30-0+deb9u1 (Zend Version 3.0.0)
Modules : apache2handler | calendar v7.0.30-0+deb9u1 | Core v7.0.30-0+deb9u1 | ctype v7.0.30-0+deb9u1 | curl v7.0.30-0+deb9u1 | date v7.0.30-0+deb9u1 | dom v20031129 | exif v7.0.30-0+deb9u1 | fileinfo v1.0.5 | filter v7.0.30-0+deb9u1 | ftp v7.0.30-0+deb9u1 | gd v7.0.30-0+deb9u1 | gettext v7.0.30-0+deb9u1 | hash v1.0 | iconv v7.0.30-0+deb9u1 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.30-0+deb9u1 | mbstring v7.0.30-0+deb9u1 | mcrypt v7.0.30-0+deb9u1 | mosquitto v0.4.0 | mysqli v7.0.30-0+deb9u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ | openssl v7.0.30-0+deb9u1 | pcre v7.0.30-0+deb9u1 | PDO v7.0.30-0+deb9u1 | pdo_mysql v7.0.30-0+deb9u1 | Phar v2.0.2 | posix v7.0.30-0+deb9u1 | readline v7.0.30-0+deb9u1 | redis v4.1.1 | Reflection v7.0.30-0+deb9u1 | session v7.0.30-0+deb9u1 | shmop v7.0.30-0+deb9u1 | SimpleXML v7.0.30-0+deb9u1 | sockets v7.0.30-0+deb9u1 | SPL v7.0.30-0+deb9u1 | standard v7.0.30-0+deb9u1 | sysvmsg v7.0.30-0+deb9u1 | sysvsem v7.0.30-0+deb9u1 | sysvshm v7.0.30-0+deb9u1 | tokenizer v7.0.30-0+deb9u1 | wddx v7.0.30-0+deb9u1 | xml v7.0.30-0+deb9u1 | xmlreader v7.0.30-0+deb9u1 | xmlwriter v7.0.30-0+deb9u1 | xsl v7.0.30-0+deb9u1 | Zend OPcache v7.0.30-0+deb9u1 | zlib v7.0.30-0+deb9u1
Pi
Model : Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
Serial num. : 32F2D088
Temperature : 47.24°C - 47.8°C
emonpiRelease : emonSD-30Oct18
File-system : read-write
Client Information
HTTP
Browser : Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:71.0) Gecko/20100101 Firefox/71.0
Language : en-US,en;q=0.5
Window
Size : 1519 x 750
Screen
Resolution : 1536 x 864
