Unable to Read 'Emoncms In' node data
I am unable to read data from my EmonPi using the ‘emoncms in’ node in Node-Red. I’m getting this error:
10/31/2023, 12:37:43 AM [node: EmonPi LR] msg : error
“Error: connect ECONNREFUSED 192.168.1.11:80”
I’m hoping someone can help. Thanks
Are you using the Read/Write API key (not the read only key) for the local instance?
Anything in the emoncms logs?
[edit]
Can you paste your config, please (less API key) - use Ctl-E to format it.
