When I try to load up my emonpi local webpage this is what I get:
Can’t connect to database, please verify credentials/configuration in settings.php
Error message: Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)
I know I probably need to reinstall the image file on the SD card. But I would like to keep all my current data. Is there a way that I can keep all my configuration and usage data? Maybe copy the info directly over?
pi@emonpi(ro):~$ sudo systemctl status mysql.service
● mysql.service - LSB: Start and stop the mysql database server daemon
Loaded: loaded (/etc/init.d/mysql)
Active: failed (Result: exit-code) since Tue 2017-10-03 08:17:09 UTC; 34min ago
Process: 914 ExecStart=/etc/init.d/mysql start (code=exited, status=1/FAILURE)
Oct 03 08:17:08 emonpi systemd[1]: Starting LSB: Start and stop the mysql database server daemon…
Oct 03 08:17:09 emonpi mysql[914]: /etc/init.d/mysql: ERROR: The partition with /home/pi/data/mysql is too full! … failed!
Oct 03 08:17:09 emonpi systemd[1]: mysql.service: control process exited, code=exited status=1
Oct 03 08:17:09 emonpi systemd[1]: Failed to start LSB: Start and stop the mysql database server daemon.
Oct 03 08:17:09 emonpi systemd[1]: Unit mysql.service entered failed state.
I undrestand that the disk is full - how I can delete some information
That’s odd that your data partition should be full. You might want to expand it if your SD card is big enough. There is a script which will do this, but I never used it so I can’t vouch for it (I expanded my partition manually). It might be simpler to try to free up some space. Start by running these commands:
df -hlx tmpfs # Show local filesystems except tmpfs in human-readable format
sudo du -shc /home/pi/data/* # Show top level directory sizes.
I think it would be useful for the community if you could post the results here so that we can find out where all the space has gone.
I actually ended up reinstalling the software and restoring from a backup. And then I used the script to increase the data space. Everything has worked great since.
