I get a strange issue : when I have to reboot the emonpi, specific tcp ports (for mqtt and a custom socket interfacer for instance) are not opened, although “ufw status” show proper ports set to “ALLOW”. Any incoming packet gets dropped (appart from 80, 443 and 22). I have to run"rpi-rw", “ufw restart” and “rpi-ro” to get ports to be effectively opened.
JS - Sorry I don’t have an answer but I may be able to point you in the right direction. I think you are looking for iptable persistence. Take a look at this OEM blog emonPi, NodeRed and MQTT in the section titled Install Node-RED on emonPi / emonHub / Raspberry Pi.
Hmmmmm, I don’t have any emonSD file in /boot… barely an emonpi-28May2015…
Is there an “upgrade path” ? Can I backup all config and data and build a new SD ?
Where did the image your running come from? Did you built it yourself or is it one of our early images? If so this is strange since we only started using UFW in recent image builds. What Emoncms version are you running (see Emoncms footer).
Yes, you can use the emonPi backup / import module to migrate your data. Running an emonPi update should install the backup module. If you are running a very old image (older that May15) then you might need to manually install the backup module to generate a backup zip with your data. Importing into the latest image is then straightforward. See user guide :
This is because it was recently installed as part of a recent emonPi update . We have been trying to make it as easy as possible for users to migrate to the new image. Once you have the new image running you should be able to follow the guide:
