Hi, I have a random question with regards to the output of my UFH. I had a Daikin Altherma3 8KW installed in my Victorian terrace. The system as such works (hot water, also zone heating as such), but the UFH doesn’t seem to manage to heat up all areas well enough during the winter. The parts of the house with wooden floor boards is absolutely fine, but the bits with either tiles (kitchen/bathroom) or engineered wooden floor (UFH compliant) are struggling. When the builders installed the UFH, they couldn’t use spreader plates because of the space available between the joists, so they put insulating kingspan boards underneath to reflect the heat.
I’ve already moved the WD upwards, and I’ve reduced the flow rate in the affected rooms, but it only had a tiny effect. Does anybody else have a similar problem, and/or any advice/suggestions?
Many thanks for your help!
