I need to be able to update older datapoints in a pulse-based feed of gas usage, but cannot reliably go back further than a handful of intervals. I am beginning to suspect that RedisBuffer may be impacting on my attempts, giving me inconsistent results. Can anyone tell me if this is an issue with RdisBuffer? Or suggest a better way to acheive the updates? I am currently pursuing two strategies, the first is a modified log to feed to update the datapoints in the actual feed, and the other is to do so in the web app. I have modified a copy of mysolarpv that replaces the solar data with my gas data. I will probably end up renaming this to MyDualFuel when it is properly polished. But that’s a separate issue.
I am recording the durations between pulses from my gas meter, each pulse representing one cubic foot of gas consumed. Dividing the Joules of that cuFt (1146052.8J) by the duration in seconds gives me a flat rate of gas consumption in Watts. This is logged to a feed at 10s intervals.
The resulting value is valid not just at the time of the pulse, but for every second of the duration back to the previous pulse, so I need to write the Watts value into all of the relevant datapoints in that duration, though I limit that to 10 minutes if the duration was longer than that. However, it doesn’t matter how I limit the update range, if it is longer than about 3 intervals ago, it just runs away and overwrites anything from four to many tens of intervals, even when the loop is explicitly limited to four cycles writing a single datapoint per cycle. I am pulling my hair out as after weeks of trying to diagnose the problem I cannot seem to get a handle on it. Any ideas?
This is why I have started the second strategy of intervening in the in-browser Timeseries, and appying the retrowrites in the copied data there, as a self-contained process that doesn’t need to write anything to the actual feed. I have high hopes that this will work if it doesn’t take too long during every reload.
Mike Sims
