I was a little bit annoyed in having to always add a text widget to name a bar widget so I added the option to add a title to it and also be able to select a different color than the bar itself to have a good contrast.
Thanks, could you post a screenshot demonstrating how this works and if possible please submit an emoncms pull request on Github. We can then review and merge changes if this is deemed useful.
I also did it for my PV Widget but there only a title field is visible and the text colour is because of the darker background the same as for the value
Here is a live example of a user:
Or here is a live demo of a client using the bar charts just for PV:
In this example the serial number of the micro inverters attached to the panel is shown.
My original intention is actually to use the Feed “Tag” value. Does someone know where to get it? Which file is responsible to get the feed value from the feed id?
In My Solution it would solve a lot of manual effort to have the title using the feed tag. When I onboard a client with their Enecsys Inverters I have a script which creates 8 Feeds per Inverter. They are all grouped to the tag, which is the inverter serial number. So adding a PV Widget then would automatically lookup the tag of the feed and use it as title.
It seems legit to me. I’d be happy to review a PR when you’re ready for that @Andreas_Messerli. Have you thought about doing a PR for the PV widget as well? I’d certainly make use of that!
Will do a PR later. Can someone make some tests with it? It seems to break existing bar widgets which is odd because the PV Widgets I have done are working normally with this addition.
When you do not enter a title it just does not shown anything and it should work as the normal bar widget.
Can’t we do a Dashboard section here in the forums? A dedicated one for dashboard development?
I’m thinking of adding also a font picker to it with some preset fonts so that you can change the font of it.
I have the following widgets done:
Vertical and horizontal PV Widgets (posted on forums)
LED Widget enhanced with size option (posted on forums)
Digital Compass widget (posted on forums)
Windrose Compass Widget (posted on forums)
Jgauge with a 2nd needle to have 2 values shown on the same gauge (posted on forums)
I need to figure out how I can do a pull request on it. I have my own fork of EmonCMS and done some enhancements to it but I’m still on an older code base 9.1. Can I do a pull request from my fork with dedicated subset of files? Or is it better to fork the actual code base and add my changes there?
I later try to add this to the text widgets… I’m not a pro when it comes to coding so it takes some time
I named it bar2 for now and can be downloaded for test here: Dropbox - bar2.rar - Simplify your life
Just add it to the widget folder and it should be good to go.
Tested your bar 2 widget, the only issue I see is that when you go back to edit the color for the title reverts back to black rather than keeping the color you had previously selected.
Just brainstorming here, but maybe add some kind of identifier to newly created widgets, keep the old code but only apply the new code to bar widgets that have the identifier or version number embedded in them?
Just an idea, hope this helps or at least inspires another idea that works better.
