I would like to connect a DS18B20 temp sensor by Serial Direct connection directly to a Raspberry Pi running emoncms.
The emonhub.conf file would contain the EmonHubSerialInterfacer.
Any suggestions or pointers?
Thank you
Hi John,
There are many articles, tutorials, etc on how to do that. A Google search turns up lots of them.
Here’s an example of how to connect the hardware:
http://www.circuitbasics.com/raspberry-pi-ds18b20-temperature-sensor-tutorial/
That said, the connection isn’t - as the term is used here - Serial Direct, but rather to one of the GPIO pins on a Pi. While the data flow is indeed serial, the term Serial Direct as applied to OEM is generally understood to mean a serial connection via the UART, i.e the comm port.
This thread: Reading DS18B20 temperature sensors with a RFM69PI?
Should help with the software.
There are other threads that cover the use of the DS18B20 with emonCMS.
A forum search for DS18B20 should help you find the info you need.
