Community
OpenEnergyMonitor
OpenEnergyMonitor Community
System access
Can you allow someone else to view your system with the read only key, if so what is the url you use.
Hello @jonharnew, you can add ?apikey=APIKEY to the page you want to share and if its content is compatible with the read apikey it will work. If there are already URL parameters presenet use the and character e.g: &apikey=
Thanks for that just replaced ? with & and it worked fine
