Hello ,
I am new to the world of Linux and servers but have pretty good grasp of basics of database etc.
Here i the problem. I installed Emoncms on my Synology NAS DS214 with .DSM 6.1.1-15101 Update 4
EMONCMS is 9.8.6 | 2017.05.10
when I try to create feed I get the error- “ERROR: Feed could not be created, undefined”
Same error for PHPFINA and PHPFIWA engines
The emoncms log shows entry - ERROR|PHPFina.php|create_meta() could not write meta data file fopen(/var/lib/phpfina/8.meta): failed to open stream: Operation not permitted
2017-05-28 15:00:53.806|WARN|feed_model.php|create() failed to create feed model feedid=8
following is the log from debug console -
jquery-1.11.3.min.js:5 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/.
view:370 Object {id: “16”, nodeid: “3”, name: “batteryamps”, description: “”, processList: “1:2”…}
view:385 contextid=16
view:385 contextprocesslist=1,2
process_ui.js:23 contextid=16
process_ui.js:24 contextprocesslist=
view:370 Object {id: “26”, nodeid: “3”, name: “BMVMidpoint_Deviate_Voltage”, description: “”, processList: “”…}
view:385 contextid=26
---- I have checked the directory permissions on NAS
drwxrwxrwx 2 root root 4096 May 28 15:27 phpfina
drwxrwxrwx 2 root root 4096 May 28 15:27 phpfiwa
drwxrwxrwx 2 root root 4096 May 28 15:27 phptimeseries
