Hello all, this is my first post.
Currently using diverted surplus solar power to charge a 100Ah 16s LifePO4 battery however its largely a manual process that need automating. Battery power is then used for peak clipping and to supply the houses static load. It works very well and has been in use since Sep 2025. The diverter exports about 100w to grid for one or two seconds as its decision logic works out which way to go having said that a PJ1103C dual sensor says that a continuous 100W is being exported back to grid except at night, not sure why.
Thinking of using a binary up/down counter/integrator to control a charger load bank. The chargers are rated as 100W, 200W, 400W, 800W. A diverter needs to have two control outputs and an operating dead band. With =>100W of grid consumption the counter counts down removing load, if solar surplus is >=100W counter counts up increasing load. When in between the two the counter stops counting.
When the load bank cannot remove all surplus power it is dumped to an air heater. The PV array is 1.5kWp so little or no surplus power is wasted, essentially all of the surplus power is put to use.
So what diverter is best suited to my needs? ![]()
