BazCal
(Barry Caldwell)
8 February 2017 20:45
#1
I’m building a couple of emonTx boards and trying to source all the parts. My only doubt is the Mini-USB b socket.
Can anyone recommend a matching part-code from e.g. RS or Farnell?
Many thanks, Barry.
pb66
(Paul)
12 February 2017 21:07
#2
From memory I think they may be sourced from rapidonline perhaps @glyn.hudson ot @TrystanLea can confirm.
USB socket is Farnell: 565790511
BazCal
(Barry Caldwell)
13 March 2017 20:15
#5
Sorry for another dumb question but I’ve lost the emonTX V2 build guide… all links seem to take me back to the home page.
Can anyone point me in the right direction? I have all the parts and the Eagle files, just want to sanity-check before I start soldering.
Many thanks, Barry.
The emonTx V2 firmware, hardware design and build guide are all together in the emonTx V2 repo on github:
emonTx V2 (through-hole design): A low power, wireless energy monitoring node based on Arduino / JeeNode - GitHub - openenergymonitor/emontx2: emonTx V2 (through-hole design): A low power, wireless...
# emonTx V2.2 Build Guide
If you run into problems please post on the [Community Forum](https://community.openenergymonitor.org).
The PCB is built in an orderly sequence starting with the resistors and small components that are low on the board, then working up to the bulkier parts like connectors. After soldering each component, you need to cut off the excess component leg from the bottom using some cutters.
It is very easy to cause shorts which will make the board or specific parts of it not work, take your time during the build, be precise, use minimal solder and carefully check each joint after soldering it. If you suspect any short, check it with a multimeter and fix any shorts there and then, before continuing.
If you're new to soldering or looking to improve your technique we highly recommend these videos:
* [EEVBlog Soldering Tutorial - Part 1: Tools](http://www.eevblog.com/2011/06/19/eevblog-180-soldering-tutorial-part-1-tools)
* [EEVBlog Soldering Tutorial - Part 2: Soldering](http://www.eevblog.com/2011/07/02/eevblog-183-soldering-tutorial-part-2)
* [EEVBlog Soldering Tutorial - Part 3: Surface Mount](http://www.eevblog.com/2011/07/18/eevblog-186-soldering-tutorial-part-3-surface-mount)
It's recommended you read through the whole of this guide and familiarise yourself with the steps before you start the actual build.
## Step 1 - Identify Components and Kit Contents
Lay out and identify the components from the kit.
This file has been truncated. show original
Thanks for reporting the broken link, I will set an auto redirect.
