With Emoncms V 10.0.2, some of MySolar values at the bottom of the history bargraph don’t change when moving the mouse on an other day bar.
As you can see on screenshots (obtained by moving the mouse first on June 07, then on june 06 bar), “Use” and “Solar” values and “Direct”, “Export” and “Grid” percentage change but “Direct”, “Export” and “Grid” values are the same for the both days.
However, if you click on the one-day bargraph to get the power vue, all displayed values at the bottom will update.
