Hello everybody, I’m making my final degree work and I’m making a similar Project to openenergymonitor.
I would like to know how can a convert the read value from SCT-013-000 to a correct current value without using emon library.
The library Works fine but I cannot use it in my Project.
Could You help me please?
thanks
I think you need to read the “Building Blocks” section of “Resources” to learn how to measure alternating current. All is explained there.
Ok, I will try it
Thanks Robert
Basically, one way or the other you must do the same general procedure that emonLib uses, which is much the same as all the energy monitoring ICs do. You can find some good references and software listings in Atmel’s application notes.
