Hi everyone,
I have my IoTaWatt that is sending his data via Wi-Fi on my emonpi, and some emonth and tx that are sending their data to the same pi via radio signal. I want mi emonpi to send all these data to my server that is running emoncms. The fact is that it is doing it well for the inputs that are sending via radio signal, but I didn’t find how to send the data received from the IoTaWatt. I precise that I can’t send directly the data from the IoTaWatt to my server, because of some certificates problems on my server’s side I can’t resolve.
I am pretty sure it is possible to do it and maybe the solution is right there in front of my eyes but I think I need some help to see it.
I am posting this topic on this forum because I think the problem does not come from the IoTaWatt, for example you can replace the IoTaWatt by another emonpi pushing data in Wi-Fi to the emonpi I have, in my opinion it would be the same situation.
Finally, here’s my emon hub config :
####################### emonhub.conf #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
### loglevel must be one of DEBUG, INFO, INFO, ERROR, and CRITICAL
loglevel = INFO
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[RFM2Pi]]
Type = EmonHubJeeInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 38400 # 9600 for old RFM12Pi
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
group = 210
frequency = 433
baseid = 4 # emonPi / emonBase nodeID
calibration = 230V # (UK/EU: 230V, US: 110V)
quiet = true # Disable quite mode (default enabled) to enable RF packet debugging, show packets which fail crc
# interval = 300 # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 1
nodevar_format_enable = 1
[[emoncmsorg]]
[[[init_settings]]]
url = https://outils-numeriques.ines-solaire.org/mesuresPEB
apikey = 0f8139cd5cc14ad17c737fc6ae53556a
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 0 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
[nodes]
## See config user guide: https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
[[4]]
nodename = emonpi2
[[[rx]]]
units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
nodename = emontx6
[[[rx]]]
units = W,W,W,W,V,C,C,C,C,C,C,p
[[7]]
nodename = emontx7
[[[rx]]]
[[8]]
nodename = emontx8
[[[rx]]]
[[20]]
nodename = emonth20
firmware = emonTH_DHT22_DS18B20_RFM69CW
hardware = emonTH_(Node_ID_Switch_DIP1:ON_DIP2:OFF)
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacode = h
scales = 0.1,0.1,0.1,0.1
units = C,C,%,V
[[21]]
nodename = emonth21
[[[rx]]]
datacode = h
units = C,C,%,V
[[22]]
nodename = emonth22
[[[rx]]]
datacode = h
units = C,C,%,V
[[23]]
nodename = emonth23
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
[[24]]
nodename = emonth24
[[[rx]]]
units = C,C,%,V,p
[[25]]
nodename = emonth25
[[[rx]]]
units = C,C,%,V,p
[[26]]
nodename = emonth26
[[[rx]]]
units = C,C,%,V,p
[[27]]
nodename = emonth27
[[[rx]]]
units = C,C,%,V,p
[[28]]
nodename = emonth28
[[[rx]]]
units = C,C,%,V,p
[[29]]
nodename = emonth29
[[[rx]]]
units = C,C,%,V,p
[[30]]
nodename = emonth30
[[[rx]]]
units = C,C,%,V,p
[Formatted for presentation - Moderator (RW)]
