I have an ESP32 device connected to the F1 and F2 terminals and the 12V terminals, which I find very useful as it provides for the display of data and enables changing of settings from my phone or laptop without going through the service menu eg FSV 5051. I can also change the offset, even though this is not displayed on my controller as I use the controller’s thermostat (2091/2 Not use). The credit for this goes to Beormund GitHub - Beormund/esphome-samsung-nasa: This component enables modern Samsung Heat Pumps to be integrated into ESPHome and Home Assistant. It supports NASA heat pumps that utilize the MIM-E03CN / MIM-E03DN & MIM-E03EN control boards · GitHub
I would like to install the Wifi kit and therefore have the possibility of signing up to Havenwise (in case of something happening to me or for the sake of any future owners). This kit uses the same connections as the ESP32, so I could just disconnect the ESP32 and connect the 4 wires to the Wifi kit. However, I don’t want to lose the ESP32 functionality.
- Can anyone tell me if they can safely be both connected at the same time?
- Would I need to run a separate 4 stranded cable to F1 and F2 and the 12V terminals?
My knowledge of electronics is limited. I imagine that the 12V supply could manage both devices, but don’t know the effects of getting this wrong. Any advice would be much appreciated.
