I have AE120MXTPEH paired with AE160BNYDEH that is feeding total of 8 underfloor loops with max lpm of 20. The loops are hydrostatically balanced and they stay in ~0.5C band temp difference in their returns to manifold. Heating area is approximately 150m2
This is an 8 hour snapshot from last night. Outside temperature around 6C. Compressor capped to max 60% (translating to 30Hz) via 0x42F1, if not capped it goes into on/off limbo, I am not able to dissipate more energy, the sizing of the pipes must have been done wrong, its 20cm spacing, or something else, anyhow. There are no thermostats or water laws, manifold returns are fully open, DHW off.
I have couple of questions regarding the operation of the system. Will be very thankful if there are experts here that can make any sense out of this.
I do not understand the events around 4:30am and 8:00am, the first one appears to be close to a slight overshoot of the return temp over the target, but the second one is mystery to me. They both have similar graph signature and they both kept the compressor off for exactly 90 seconds. During this two events it appears that the hydromodule actually started to cool down the flow. The question is, what are those events, where did the heat transfer? there was no defrost recorded, also outside temps did not suggest one, why they are messing perfectly balanced system and sending it in a frequency hunt again, the system never recovered after the second event, i have to pull the plug on it.
Water pump never received instructions other than 100% PWM but it is also visible that it is hunting for something (delta T target is set to 4C , control factor is 2) why the lpm is changing, does the built-in pump also have some own microcontroller or there is something else going on here.
I am storing full history of all registers in influxdb and can query any history data if that will be helpful.
