Excellent write up! Lots of useful information ![]()
It’s probably useful to state that this post is about the Gen7 HTQ range i.e R32 high temperature. There is also an R32 Gen 6 range, a new R290 range, both the R290 and Gen 6 range also 5kW and 16kW models.
A useful thing to note is that apparently the HTQ range share the same compressor between the 8kW, 12kW and 14kW models, therefore the low-end modulation on the 8kW and 12kW models is possibly not as low as it could be.
I’ve also had a good experience with Samsung heat pumps and I would recommend them. However, the controller is not the easiest to understand compared to other brands, and they require quite a bit of tweaking to get running well. But then can give excellent performance. I’ve installed a couple of them (specifically 5kW Gen 6), which are both in the top 10 systems on https://heatpumpmonitor.org.
