If you have a keyboard and monitor connected to your emonBase,
execute the command sudo poweroff
If you don’t have a keyboard and monitor connected,
execute the command ssh pi@ip_address sudo poweroff
you’ll be prompted for the emonBase password. After you enter the password, the command will run.
You may get an error message about a broken pipe, but it can be ignored.
Hi folks all taken onboard. On a diffrent note i have a PI based energy monitor from America, Its quite smart.
It uses a small remote shutdown button connected to the I/O ports and runs a python script to shut it down safely.It makes it foolproof.
I may open another post on this unit later. I used for offgrid generator monitoring . Here is the basic outline and link Useful Bits and Bytes: Multichannel Professional Data Logger on Raspberry Pi - Part 2
Software tools, applications and frameworks I found interesting or useful. Mostly around Java, Maven, Teiid, wit…
emonpi.local works on the standard emonSD image on Ubuntu Linux with Chrome / Firefox and also tested to work on Android Chrome. No extra services required. I imagine Avahi is running as standard on Ubuntu and Android. Tested on Ubuntu 16.04 and Android 7.
Yup, nice solution. We do the same on the emonPi, use a button to trigger shutdown via GPIO pin. The emonPi shuts down if GPIO 11 is low for 5s then the emonBase will shutdown:
On the emonBase since no LCD is detected this python scripts exits, you can override this by commenting out this check:
But… If the box you’re issuing the command from isn’t running Ubuntu or isn’t running avahi, it doesn’t work.
If the box issuing the commend is running Windows, (unless it’s running Bonjour or an equivalent) it won’t work there either.
I just tried shutting down a Pi (running the latest emonSD image) from a machine running Debian (no avahi) and received this error message: Could not resolve hostname emonpi.local: Name or service not known
No joy with PuTTY on Windows 7 either. Even though Windows isn’t the world’s most liked OS, there are too many Windows boxes in use to just turn a blind eye to them.
