Hi!
Haven’t added any new feeds recently, but now I am having trouble when creating new feed from input, or to change already existing feed.
I have upgrades to ubuntu 16lts and php7. everything else seems to be working ok.
Any thoughts where to look? All the paths and permissions are ok and verified.
// Engines working folder. Default is /var/lib/phpfiwa,phpfina,phptimeseries
// On windows or shared hosting you will likely need to specify a different data directory--
// Make sure that emoncms has write permission's to the datadirectory folders
'phpfiwa'=>array(
'datadir' => '/var/lib/phpfiwa/'
'phpfina'=>array(
'datadir' => '/var/lib/phpfina/'
'phptimeseries'=>array(
'datadir' => '/var/lib/phptimeseries/'
Server Information
Emoncms Version 9.7.7 | 2016.10.29
Modules admin, app, dashboard, event, eventp, feed, input, process, schedule, time, user, vis
Server OS Linux 4.4.0-45-generic
Host server server (127.0.1.1)
Date 2016-11-03 23:09:33 EET
Uptime 23:09:33 up 1:02, 1 user, load average: 0,01, 0,02, 0,04
HTTP Server Apache/2.4.18 (Ubuntu) HTTP/1.1 CGI/1.1 80
Database Version MySQL 5.7.16-0ubuntu0.16.04.1
Host localhost (127.0.0.1)
Date 2016-11-03 23:09:33 (UTC 02:00)
Stats Uptime: 3700 Threads: 1 Questions: 5088 Slow queries: 0 Opens: 185 Flush tables: 1 Open tables: 100 Queries per second avg: 1.375
Redis Version 3.0.6
Host localhost:6379 (127.0.0.1)
Size 114 keys (517.22K)Flush
Uptime 0 days
Memory RAM
Used 7,33%
Total: 5,75 GB Used: 431,46 MB Free: 5,33 GB
Swap
Used 0,00%
Total: 7,45 GB Used: 0 B Free: 7,45 GB
Disk Mount Stats
Used 9,36%
Total: 139,14 GB Used: 13,02 GB Free: 119,03 GB
/var
Used 1,45%
Total: 146,46 GB Used: 2,13 GB Free: 136,87 GB
/run/cgmanager/fs
Used 0,00%
Total: 100 KB Used: 0 B Free: 100 KB
PHP Version 7.0.8-0ubuntu0.16.04.3 (Zend Version 3.0.0)
Modules Core date libxml openssl pcre zlib filter hash Reflection SPL session standard apache2handler mysqlnd PDO xml calendar ctype dom exif fileinfo ftp gettext iconv json mcrypt mysqli pdo_mysql Phar posix readline redis shmop SimpleXML sockets sysvmsg sysvsem sysvshm tokenizer wddx xmlreader xmlwriter xsl Zend OPcache
I am grateful for any info, what helps me on…
Kristo
